Control Lines For all you fly-by-wire fanatics!
Phantom from scratch
Old 07-30-2009 | 03:55 PM
Default RE: Phantom from scratch
All the building except for the cowl is done, and that is well under way. the filling, sanding, and sealing is done and I have started the covering.
ID:	1246595   Click image for larger version
Old 08-02-2009 | 02:46 PM
Nearly finished. All the covering is on and doped. The cowl has been fitted and there is just the front to do. As a spinner of that size would hit the fuselage and look out of place I am just going to cover and then paint a couple of air intakes on the front disc.
I had to recover the elevator and am still not happy with it so it will be redone again.
Next is sanding the whole model and applying the finishing coats of paint and if needed a fuel proofer.
ID:	1248720   Click image for larger version
ID:	1248721   Click image for larger version
