Control Lines For all you fly-by-wire fanatics!
Skyray 35 plans
Old 08-27-2009 | 04:12 PM
Default Skyray 35 plans
Hi, any fellow has the plans from the Skyray 35 in PDF, TIF... ? Related models serves too..
many thanks
Old 08-27-2009 | 05:43 PM
Default RE: Skyray 35 plans
Skyray 35 plans are available from SIG and since they are copyrighted I would suggest you get them that way.
Bob Furr
Old 08-29-2009 | 09:46 AM
thanks, i´ll be in touch with them
Old 08-29-2009 | 05:20 PM
gcb
Since you are building from scratch, there are some suggested improvements to the Skyray 35. Use balsa full ribs instead of the plywood ribs and half-ribs, use a two wheel landing gear, variable wingtip weight, adjustable leadouts. Brett Buck suggested the first mods I remember reading about. You can probably do a search on the Skyray to see various suggestions.
George
Old 09-01-2009 | 11:37 AM
My Feedback: (7)
I decided to build one from scratch also but I made some other changes that included:
1) foam wing with 1/32 balsa skins
2) electronic single channel throttle control, servo, battery and on/off switch was buried inside the wing
3) built up profile fuselage, 1/16 balsa sides with 3/8" square sticks inside, this proved to be stiffer than the typical 1/2" thick solid balsa fuselage
4) Fiberglassed and then painted the model with latex house paint with nelson clear coat
The model flew great and I did not change any of the dimensions.
Old 09-01-2009 | 12:04 PM
Thanks by the tips guys !
Old 09-02-2009 | 11:08 AM
gcb
Fred,
How did the 1/32" wing skin work out? I've heard some that said 1/32" is too thin to lay flat.
George
Old 09-16-2009 | 11:40 AM
My Feedback: (7)
I have built several models with 1/32" balsa skins with no problem. I have used the southern sourgum for bonding the skin. I also fiberglass my models and paint them with latex house paint.
