Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
Resurrecting a Great Plans 1/3 Scale Pitts Special ARF
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 03-14-2019, 07:12 PM
erans
Final touches on the secondary spar reinforcing with plywood shear web and reinstating the balsa shear web on the other side
Old 03-17-2019, 09:37 PM
erans
I was doing some of the minor cosmetic fixes.
Old 03-17-2019, 09:41 PM
erans
Some more filler and sanding, and another crack in the sheeting near the wing tip fixed and re-covered. Before re-covering I inserted a "rope" to pull the servo wire later on.
Old 03-22-2019, 05:25 AM
erans
Quite a bit of work was done since last time I posted.
First, covering all the areas with issues - bottom wing
Old 03-22-2019, 05:27 AM
erans
Covering - Continue...
Old 03-22-2019, 05:33 AM
  #31
erans
With the wing covering completed, the bottom wing to fuselage attachment was checked. This was found to be unsatisfactory with the wing not sitting properly in the saddle. After some sanding of the locator pins holes (mating area of the LE and fuselage) the wing attached properly.
Old 03-22-2019, 05:34 AM
  #32
erans
Next was fitting the top wing, which had no issues.
Old 03-23-2019, 01:16 AM
  #33
erans
I fitted some of the radio gear. I made mounts for the different components. In addition, I substituted the Chinese "Hao ye" switch and ignition switch which had a soldering done on one of the leads with hew Hitec switch and the Spektrum "fail on" switch that comes with the Power Safe receiver.
Old 03-23-2019, 01:19 AM
  #34
erans
More photos of radio gear instalation
Old 03-24-2019, 04:32 PM
  #35
erans
The top wing had only some cosmetic issues, which were easily fixed
Old 03-24-2019, 04:37 PM
  #36
erans
While looking at the ignition battery connection, I found a suspicious soldering, which was uncovered and re-done properly.
Old 03-24-2019, 04:40 PM
  #37
erans
To check that the ignition operates as it should with the repaired cable, and to see if the engine actually works after years of storage, I quickly fired it up on my test stand outside. All worked perfectly.
Old 03-26-2019, 07:00 PM
  #38
erans
Couple of important things that happened:
1. While on the stand running the engine, I noticed that one of the elevators hinges is torn (CA hinge)
2. The owner reconsidered the costs associated with getting this aeroplane to flying condition (Heavy Duty servos, flight batteries etc) and decided to give it to me at no cost...
So, first thing first, cutting the elevator off and re-hinging
Old 03-26-2019, 07:04 PM
  #39
erans
And while at it with the "rigging" wire disconnected, I fixed the covering on the horizontal stabiliser
And then, re-"rigging"
Old 03-29-2019, 12:32 PM
  #40
jescardin
Erans, congrats on the restauration work!
I have a similar job ahead but with a Christen Eagle instead of the Pitts.
Please keep us informed on the project progress, the large model inspection results and the maiden, of course.
Best Regards.
Old 03-29-2019, 11:41 PM
  #41
erans
Thank you jescardin, I hope you will enjoy restoring the Christen Eagle as much as I do with the Pitts.
I set up the Pitts on my JR transmitter and went ahead with installing the tail servos. This required placing some hardwood for the servo screws to have something to bite into.
Old 04-02-2019, 12:19 AM
  #42
erans
Doing some bits and pieces around the front of the aeroplane.
The Cowl cutting has been enlarged to clear the muffler stacks . "servo screws" were used to mount the cowl to the fuselage.
I installed the Rcexl electronic kill-switch and associated LED light, and extended the fuel tank vent line to exit from the cowl bottom.
Simple fuel dot was attached to the cowl, and a filter inserted on the fuel line to the carburettor.
Old 04-05-2019, 07:16 PM
  #43
erans
Got the servos into the wing. The bottom wing had a string put in when repaired to pull the servo extension leads to the exit at the centre. For the top wing I used fuel tank clunk as a weight to thread the string, which worked well.
I also repaired the exit hole for the wires in the top wing.
Old 04-05-2019, 07:22 PM
  #44
erans
Next was setting up the ailerons direction and amount of travel as per the recommendation in the manual.
The Pitts looks quite good fully assembled.
Old 04-06-2019, 11:31 PM
  #45
erans
Since this aeroplane is now my aeroplane, I will be using LiFe batteries instead of the NiMh that the previous owner wanted.
In addition, I use common batteries on my aeroplanes which require easy access mounts. So, ripping the "old" mounts and making new ones...
Old 04-08-2019, 09:51 PM
  #46
erans
When I had the aeroplane assembled, I was still not entirely happy with the way the bottom wing sat in the saddle. The belly-pan was interfering. I therefore had it trimmed and the belly pan re-covered.
Old 04-08-2019, 09:58 PM
  #47
erans
While at it, I repaired the covering on the bottom of the wing...
Old 04-09-2019, 04:55 PM
  #48
foodstick
foodstick's Avatar
Wow, there will be no sign of a previous crash when you are done.. Awesome work.
Old 04-09-2019, 09:41 PM
  #49
erans
Thank you foodstick, I appreciate your comment. While I will attempt to fix most covering issues I already decided to leave the two white areas on the bottom wing until after the test flight. I cannot be bothered with it at the moment : )
It was time for another engine run to verify that all is working as it should. Unfortunately there were more fuel related issues and I decided to change the filter which may have been leaking air and while at it, I replaced the fuel tank which I didn't like anyway, as it was mounted on its side.
One other problem is the lack of spinner. It is specifically an issue with this CRRC Pro 45cc as there is no "shaft" for the prop and therefore no thread at the end of the shaft for standard aluminium spinner centre bolt. However, a club member offered to assist with this and invited me to visit his shed and he will "see what he can do"...
Old 04-11-2019, 12:05 AM
  #50
erans
My club mate idea for the spinner problem was to machine the M10 bold head and create a M5 thread in it...
He also machined from aluminium for me an adaptor that allows me to use the 3 hole guide to drill props and the back-plate of the spinner (until I get a drill guide made from high tensile steel).
The spinner was previously used on my Great Planes SU-31 and had the back plate drilled with 4 holes pattern.
