Twin Jet blows up
MO
RE: Twin Jet blows up
If you'll listen closely, it sounded like these fellows were chuckling about something just before the fire. I'm wondering if they hadn't installed a rocket motor for an extra burst of speed and something went awry. If the battery had blown up there wouldn't have been any control after it flared up.
BC, CANADA
LOLzzzzzzz....i agree with randall1959...u can tell the guys are just waiting for sumthing to happen...seems like they installed a rocket motor...that too on a foamie...u can see the foam melt off on approach...the guy taking the video found it extremely hilarious...well so did i
Have to agree bet it was an Estes or similar rocket motor wired to spare channel on RX, dont try this at home! And dont ask me how i know
ORIGINAL: silverdelt
ORIGINAL: dicksoucy
What am I doing wrong.. I only get audio after downloading the .AVI ?
ORIGINAL: volkan
I think what happened is that they stuck a estes rocket on it, to make it go faster....
but it all went wrong.....
THATS THE FUNNY PART! who agrees with me?
You can also hear the electric motors wind up in speed just as the rocket gives it the additional boost.
ORIGINAL: powertoys
I agree whole heartedly. I've heard of a couple of people try using Estes rocket motors on planes and the larger RC trucks. Seems they forget that these same rocket motors also have parachute deployment charges that are just as hot a gas as the propellant coming out the business end. I've seen more than one totally burned up TMAXX.
ORIGINAL: volkan
Im adding a estes rocket to my F20 (OS91), mainly as a cheap smoke system!
They dont create alot of thrust,,,but I guess its enough for a twinjet..
Volkan
NY
Didn't anyone notice the battery laying on the ground after they put out the fire? It looked fine.
Also, you can hear the motors speed up as the fire happened, and indication that there was a slight boost in speed from somewhere.
Plus they still had control after the fire.
Bogus
Bogus
TX
volkan, I two was getting error messages when trying to download. So I install the codec that you posted and it worked like a champ. Thanks for the post.
Planebeach, I enjoyed the video. Thanks for the post.
TN
I used to fly model rockets as a kid. The sound of an estes rocket firing is very memorable for me and you can hear the thing ignite just as you see the fire plume. No doubt about it in my opinion, they had a rocket strapped to it. I don't think it was the ejection charge that caused the fire because the fire was too early - it was almost immediately after ignition that the foam burst into flames.
OK EVEYBODY,
I have uploaded a smaller version of this video on my site.
It is 12meg and WMV FORMAT.
http://www.rc-expertise.com/wrap.php...os/twinjet.htm
(must be logged in)
(must be logged in)
Hi all i am from sweden and they talk swedish ,they have installed a rocket engine and hope it would go faster but the rocket did push itself in to the plane body and the fire start :-).
BC, CANADA
ORIGINAL: MagnusD
