Ti sensor
Hi all
I have two D\F one is new and the second I bought used.
The problem with the used one is that I have to trim the D\F evrytime i swiched from T\I to normal,
I see that the Ti sensors on the used D\F do not sit on the same level each other compare to the new D\F,they are solder rigid to the print and it can't be adjusted.
Please advise.
Moti
Please advise.
Moti
Hi Moti,
Are the sensors and/or the upper sensor board just a little off horizontal, or a lot? All the boards I've seen, the sensors were not perfectly horizontal, but they still worked OK. When you initialize the horizontal position with the down-right throttle, it should compensate for the sensors being a little off.
Ciao,
Bruce
Ciao,
Bruce
