Stud length
Now there's a subject line that could raise an eyebrow..
Hi Bob,
I was fiddling with my pylon prop assortment just received from APC, and when fitting one to my SJ50 last night to admire it I was concerned about the very small amount of prop stud remaining. The stud on mine measures 0.70" long, and the hubs on these 8.8" props measure around 0.56" - 0.57", leaving barely over 1/8" of thread engagement. That seems marginal to say the least, esp. with aluminum threads.
What's the scoop?
MJD
Hi Bob,
What's the scoop?
MJD
GA
MJD,
Hope I'm not intruding here, but maybe I can be a bit of help. I have a recently purchased SJ 50. Mine came with two studs, one measures 1.25" and the other a bit longer at 1.5" total length. The longer one was packaged in with the muffler screws and gasket. You may want to dig around in the box a bit and see if you have the longer one. I used it for the reason you mentioned with the pylon props.
Dave
Dave
My Feedback: (19)
OH
Hey...
Thanks for writing
The threaded stud can be adjusted a bit. Dub also has 2 sizes available if needed.
The normal installation on the prop stud, is to thread it into the crankshaft all the way until it stops, then back it out about 2 turns. You do not want it to bottom out in the crankshaft.
To make it longer, you can back the stud out a bit more. Take the stud out, thread it back in a mimimum of 8 turns. This gives you about 3/16" of adjustment.
Bob
Thanks for writing
Bob
