mah vs weight,nimh
mah vs weight,nimh
ok i hope i can get the answer i'am looking for. ok the two batteries i am comparing are a 9.6v 750 mah gws bat and a 9.6v 1050 mah cbp bat. now the 1050 weights about 2 oz more than the 750 so is the extra 300mah worth the 2 oz. in weight. if so why is it. i would like ot go lipoly but my time and money don't allow for expence and matinace of the cells right now i need some thing that is a little easer on the newbie.
oh and this is for my e-starter if that helps.
ON, CANADA
RE: mah vs weight,nimh
The 750 batt. would probably serve you better. As long as it can handle the amp draw of the motor. 2 oz. is a good % of the overall weight of the plane, The bigger batt. would just give you a longer motor run, at the cost of performance. Hope this helps.
