E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
speed control Question
Old 03-29-2006 | 06:02 PM
My Feedback: (25)
Default speed control Question
I have a phenix 25 speed control and it is rated at running 25 amps continuos and 35 amp surges.Wanted to know if I could run this speed control with my e-flight 480 brsless motor, the specs on the motor says 22 amps low and 28 amps high.If common sense is common sense then it would work right? 25 amp compare to 22 and 35 amp surge compare to 28 high amps but I dont know much about this electric stuff. Thanks in advance!
Old 03-29-2006 | 06:50 PM
Default RE: speed control Question
Yes, the 25 amp will work fine.
Bevo
