E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
battery out
Old 12-10-2006 | 02:28 AM
cap85king's Avatar
Default battery out
I bought a Tanic 2100 mah 11.1 volt LiPo battery pack for my Crazy 8. I only charge the thing for about 20-30 minutes and have short flights (don't really care until I get a Poly Charge 4 and another battery). I just started thinking about that when the battery 1: sometimes the battery charger (Electrify Triton) announced it was charged after, at the most, 5 seconds of charging, and 2: after the 20 minutes the motor could go at full power for all of 20 seconds. Anybody have any ideas?
Old 12-12-2006 | 12:04 AM
Hatty's Avatar
Default RE: battery out
What current are you charging at? Did it always do that or did it just start? Have you tried charging a different battery/charger? You're definitely not charging it all the way so something is wrong somewhere. I wouldn't use the battery until you get the problem solved since you're using up its useful battery life. LiPos are not the cheapest things in the world.
Old 12-12-2006 | 08:29 AM
Those are important questions to help figure it out. Also with a battery that size or any bigger I would recommend a balancer every so often at least. If you've only been charging the pack for 20 minutes repeatedly it is more than likely out of balance among other problems.
Old 12-12-2006 | 08:33 AM
The battery should be charged at 2.1 amps for one hour or just a little bit more. So at 20 minutes of charging it's not unusual that the motor would shut down very quickly.
What is the setup in the plane? Motor, esc?
