E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
battery problems
Old 12-24-2010 | 07:33 PM
Default battery problems
i have two batteries that refuse to charge. can i put them in the freezer or fridge for a couple hours to revive them? or is it time to purchase new?
thanks.
Old 12-24-2010 | 09:37 PM
Default RE: battery problems
If you run them down too much they become trash. Don't know any revival tricks once they are below 3v per cell.
Old 12-25-2010 | 05:34 PM
ORIGINAL: haus4350
thanks.
Putting a battery in the refrigirator won't revive a battery. That technique is used to lengthen the shelf life of a battery, not revive them. And it's only about 5%, so it's really not worth the effort.
If the battery you're speaking of is a Lipo battery, you could put it on a Nicad charger for a few minutes, under supervision. Then put it on the lipo charger. (As long as the voltage ratings are the same for both chargers.)
