Will another receiver work with the Tx
ON, CANADA
Here's one I don't think many people have tried. I've seen a few things on using a Futaba Tx with the Blade, but how about the reverse?
Can I use a Futaba or GWS 4ch FM receiver with a ch21 crystal together with the Blade CP transmitter (which in my case is ch21)? What I'm aiming to do is get into the fixed wing world too with a GWS Slowstick by outfitting the stick with a GWS 4 channel FM receiver and using my Blade CP transmitter as a 3 channel radio until I get around to spending the dough on a real transmitter (which I will do eventually when I get my next heli, just not right now, probably will get the 9ch Futaba so I don't need to buy another for a looong time).
I've been told that the GWS and Futaba 4ch FM receivers are pretty much interchangeable with each other, but I don't know whether the FM signal from the Blade Tx is compatible with them too. All I'd need from the TX would be 3 decodable channels (for elevator, rudder, and throttle on the slowstick), so I'd be counting on being able to use the collective pitch channel as the throttle channel and cross my fingers that I can ignore the effect of the throttle+collective mixing the CP Tx does.
NY
Sorry, but the mixing is permanantly in the controller I beleive. Also, GWS makes receivers that work with both JR and Futaba systems. I suppose you could try something like the Slo-v, it comes with everything you need, and is similair to the slowstick. Or you could just buy a budget radio, both Futaba and JR also make fairly inexpensive radios you could use.
ON, CANADA
Darn, I thought the way it worked was that in the transmitter the single left stick collective input was "de-mixed" into a collective blade pitch channel and a throttle channel so that with a different receiver I could drive a throttle output off the collective blade pitch signal and ignore the throttle signal. beacuse I only want to use 3 channels I thought there might be a way to use what was there, I don't care if it's non-linear, it's just a SS I'd be flying.
I'f I'm SOL I'm SOL, but I had really hoped to avoid spending money on a transmitter that I would be junking when I moved on to a more heavy-duty helicopter.
Oh well.
THanks.
Oh well.
THanks.
