E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
problem with cx
Old 10-12-2006 | 01:36 PM
Default problem with cx
Okay, my friends cx has very short flight times. The bats are new and I have changed the motors. The heli was bought new by him and he has hardly flown it. What else could it be? I would really like to get him back up in the air.
Old 10-12-2006 | 03:33 PM
Default RE: problem with cx
What do you consider short flight times?
Old 10-13-2006 | 09:29 AM
less than 1 min
Old 10-13-2006 | 10:43 AM
Heli_Harry's Avatar
I had the same problem.
Disasemble it
Clean it
Reassemble and Lube everything (sparingly) I used Molly-B grease (a little goes a long way).
Set your gear mesh.
Mine went from about a minute to about 10 or so.
Old 10-13-2006 | 12:28 PM
what are you cleaning all moving parts? motors are new so no cleaning needed there? it has been all apart and it was not really dirty. I'll give it a try though. Also has not had too much flight time maybe 30 flights maybe.
Old 10-13-2006 | 12:51 PM
Heli_Harry's Avatar
Yes clean all the moving parts.
I did not clean out the motors but I did clean off the gear on the motor.
You want to make sure no grit from the packing, etc. is in there.
Then lube the shafts where they touch the bearings, any surface that rubs another.
You can build up a lot of debris on a rubbing surface with out any lubrication in just a few minutes.
Mine was just a few weeks old and went to flight times of 1 minute as well.
The clean and lubrication fixed it right up.
Moly-b is great stuff, the stuff I have is for working on VCR's so as far as I can tell safe for plastics.
All you need is a thin film of it don't goop it on as it will then attract dust.
Good Luck!
Old 10-13-2006 | 01:14 PM
Hmm I might give mine a good clean this weekend, nice idea Harry...
Old 10-13-2006 | 02:08 PM
did you pull the servos apart too
Old 10-13-2006 | 02:17 PM
Heli_Harry's Avatar
ORIGINAL: zenchal26
No I did not open up the servos as I saw no need to
Old 10-13-2006 | 02:23 PM
shes all apart now see what happens
Old 10-13-2006 | 02:53 PM
ok better flight times now no 10min but at least it flys now. Thanks for the help my friend thanks you too.
Old 10-13-2006 | 03:18 PM
Heli_Harry's Avatar
How long are you up to?
Old 10-13-2006 | 03:42 PM
Did not really time it bat was not fully charged 3-4 min.
Old 10-13-2006 | 03:59 PM
Just ran full pack got 5-min. How are you getting 10 If I remember right he never got 10 min flight times when new. He'll be a lot happier now though at least he's getting 5 min of flight. When do you stop flying your (how do you tell it's time to land before damaging bat). I fly a cp2 with a bat monitor so it's self explanatory on mine.
Old 10-13-2006 | 04:07 PM
Heli_Harry's Avatar
I just charge and Fly (I have 3 batteries)
When it won't go up easily any more I land and recharge.
My 5+ minute battery is my weak one.
The other 2 Give me about 10 minutes.
The Moly-B must have helped plus mine is probably more broken in so things turn easier.
I also have the tail replaced with a boom, and the brass weights are pulled out of the fly-bar so it may be a little lighter over all.
Old 10-13-2006 | 05:52 PM
Psikelly's Avatar
Its possible that hes running his batteries too low and theyre slowly dying from being overdischarged. Most people dont know that you cant run down lipos too far or theyll die. As soon as you sense your heli is losing power because the battery is dying you need to shut it down. Dont try to get another 2 minutes flying out of it because youre just gonna hurt it
