cp pro pinion.
ON, CANADA
i just went to my lhs to get a main gear, but they've ran out of eflight 9t. so they gave me a e-sky 8t. i'm very well aware that the 9t will give higher headspeed, which is good for me since i'm doing mild 3d. but i think the 8t will give me more power as in torque, which should help as well since my headspeed decays very much when coming out of manurvers. i do have a 9t from my original motor, should i pull the 8t off and put the 9t on? or should i leave it with 8t?
ON, CANADA
ORIGINAL: chopperdudes
http://www.horizonhobby.com/Products...rodID=EFLH1100
ON, CANADA
thx, even though that bulliten is also in the manual as now i read it
. well, i just got impatient and tried it with the 8t. very unimpressive... very low headspeed, the motor will stall as normal. so i just anchored the old pinion out with a pair of needle nose pliers and put it on the new motor. now it runs fine. i'm just wondering now what'll happen if i put a 10t in there... i know it says that it'll shorten motor life, but i don't really care and i do have heat sink and the main 370's seems pretty tough to me.
hey i was wondering i just got a cp and it does seem very underpowered. now i have a 380 motor wich is a little bigger and definatly more powerfull. but i was wondering if the 3 in 1 would survive it?
ON, CANADA
anyone ever tried maybe a hotter 370 motor let's say 19 turn spec? i wonder how much current the stock esc's gonna take? i have a fuse installed right now. and i guess i'll just keep the 9t.
