Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 question about using different battery in Blade CPP >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-23-2007 | 08:16 AM
Default question about using different battery in Blade CPP
i got a blade cpp last weekend. been flying an axe ez (like the blade cx) for a couple weeks successfully. also been using a flight simulator with a blade cp model (FS One).
the second day with the cpp, i took it to the flying field and a couple experts checked and trimmed it out nicely. i did a little hovering but nothing to write home about. i've printed out the RADD material and plan to follow that from here on out with the blade cpp
my question is that for the first couple days using the radd approach, i was wondering if i could use the batteries from my ez? they are 2 cell 7.4v where as the batteries that came with the blade is 3 cell 11.1. i bought an extra pack for both the cpp and the ez so combined i would have 4 packs to play with. other than lower engine speed, would it be ok to use the 7.4 volt in the cpp in the initial stages of the radd training? actually less power may make it a little easier - i just dont want to hurt the electronics or anything else. the connectors are the same.
opinions / advice?? of cousr i would like to buy more 3 cell 11.1v battery packs but even with more packs, seems i would need to by additional battery charger(s) so i wouldn't spend all day charging batteries.
any advice is appreciated.
gw
Old 01-23-2007 | 10:55 AM
Default RE: question about using different battery in Blade CPP
ORIGINAL: garydogwood
they are 2 cell 7.4v...
they will work fine to get you light on the skids. this would carry you through several packs in RADDs, but it won't get much lift with 7.4V and the stock gearing/blades (flat bottoms and a 10T or even 11T pinion are best for 2S lipo). it won't hurt anything if you want to try the pack out. just be careful not to overdischarge it, since you're flight times will be short.
btw, i calculated it a while ago and i recall it required a total of 4 stock chargers and 5 packs to fly all day non-stop (minus 10min motor cool down periods).
Old 01-24-2007 | 08:05 AM
tried it out last night. it did kind of work but had to go to near full throttle to get it light. guess i'll buy more battery packs of the correct size.
gw
