E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Blade cp pro
Old 02-28-2007 | 11:03 AM
Default Blade cp pro
How do you make the cp do a flip without losing rpm and lossing altitude, i have tried it 2 time and lost like 10 ft altitude each time. Is there a secret? Or do you think its me, i did what i do on simulaters. Should i do loops wit it, or just a stand still roll? which is best, i have the brushless system in my cp pro, I have not tried to roll it yet, i need to set my radio up for stunt mode, im using jr7202. o plz help me?
Old 02-28-2007 | 11:34 AM
AeroDave's Avatar
Default RE: Blade cp pro
You're probably using more pitch than you need to. Stationary flips are all about timing, not jamming the left stick around. If you use too much pitch, and collective you'll bog the motor and lose headspeed. On the sim, try flipping with as little collect ive and as little pitch as possible to get a feel for what you need. Remember, in a flip you only need a few degreees negative, about the same as you'd use to hover inverted. Start your flip by pulling back on the right stick. You don't need it to rotate fast. At the same time, add a little positive pitch to get it climbing, just to give yourself an advantage. As the nose approaches vertical, center the left stick to give zero pitch. This will accomplish two things: one, it will keep the heli in one place, two, it will increase your headspeed. As it goes inverted pull the left stick just a bit below center. If your pitch curves are set up right tha's all you'll need. Then center the stick again when the nose is pointing down and smoothly add positive pitch as it becomes upright. Don't panic, and don't overcontrol. THe heli is designed for this move. As long as you do your job right, so will the heli. Practice this move a bit high until you get the feel for it.
