E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Blades don't spin
Old 03-08-2007 | 02:17 PM
Default Blades don't spin
Hey, I had to install a new inner shaft because the top of my original one broke. However, once I tried to start it up to test it out, the blades don't spin. When I press the right stick to the right or left, it adjusts the blades as if it's steering. However, when I use the left stick, nothing happens at all. Any ideas?
Old 03-08-2007 | 02:20 PM
Default RE: Blades don't spin
(cx2 ?) turn off your tx then turn it back on with the battery on the heli connected. let it arm. the blades should then spin.
Old 03-09-2007 | 08:00 AM
It's a CX2. I've tried doing that, but it didn't work. Other ideas?
Old 03-09-2007 | 09:02 AM
ndoren's Avatar
Is the light on the 4-in-1 solid green?
Old 03-09-2007 | 08:31 PM
On the end of the inner shaft there are two flat spots,Make sure that the flat spots are lining up with the screws on the bottom collar.
