E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Long or Short flybars?
Old 03-08-2007 | 09:31 PM
Oracus's Avatar
Default Long or Short flybars?
Anyone here prefer a long or short flybar? My CPP I shortened the flybar to 5 1/2 in on each side of the flybar frame. I think it is less responsive(good for me till I can fly this thing) and more stable. And also are there any weighted paddles that will fit a CP/CPP?
Old 03-09-2007 | 12:01 AM
Default RE: Long or Short flybars?
I would go with longer flybars. I am no expert on these things but from the research I have done on the forums, longer is better.
The extra length will not only make it more responsive but also make it more stable. I am planning on replacing my blade cp flybar with a larger one from a t-rex soon, if I can find one about the right size.
If you want to make it a little less responsive try wrapping a little solder wire around the flybar where the paddles are connected, that would probably be easier than finding weighted paddles. This helped me a lot when I was learning to fly this bird.
Old 03-09-2007 | 04:32 AM
As another option, they do sell flybar weights that dampen cyclic response =)
http://www.horizonhobby.com/Products...rodID=EFLH1165
Old 03-09-2007 | 07:54 AM
To clarify for the newbies reading everything and trying to sort it out;
A longer, and heavier flybar will improve flight characteristics on a Collective Pitch (CP) style heli because the pilot actually controls the flybar and the flybar controls the rotor.
A Lighter and / or shorter flybar will improve flight characteristics on a Coaxial (CX) style heli because the pilot actually controls the lower rotor and the upper rotor stabilizes the heli thru gyroscopic action. A shorter / lighter flybar has less ability to prevent the heli from moving.
Right?
Soloboss
Old 03-09-2007 | 04:08 PM
wouldn't a lighter flybar increase responsiveness though? i have a trex flybar on mine and it's definitely heavier, so it's more stable, however, because it's longer, i don't think i've lost any cyclic if not gained the rate.
Old 03-09-2007 | 09:04 PM
Have a look at this (part 10), it may help.
http://www.w3mh.co.uk/articles/html/csm9-11.htm
Great site, I learned a lot from it.
Old 03-09-2007 | 09:36 PM
Oracus's Avatar
WOW there is alot of really good info on that page.
The speed of response of the flybar to commands can be adjusted as follows:
# Increasing the weight of the paddles slows it down.
# Increasing the area of the paddles speeds it up
# Increasing the rotor RPM speeds it up
# Increasing the aspect ratio (span/chord) of the paddles speeds it up.
# Increasing the length of the flybar speeds it up.
So decreasing the length slows down cyclic response, and stability.
Old 03-09-2007 | 11:49 PM
yep, correct,
so it's correct that the heavier the flybar, the more stable but slower? right?
