E-Flite Pinout
Hello folks, just wondered if you could tell me the pinouts for the servos,etc on the CP Pro? got a used one with a Berg in it and need to change it back to original E-Flite Rx.
Can the E-Flite Rx work with a AirTronics Tx (of course on the same ch)
thanks for all your suggestions
with an airtronics, nope it can't. They use positive shift, but if you are switching out the Rx, then of course if it is compatible with the Tx you are using then you should be off and going =)
not sure what you mean by pin outs.
channel 1 is the rear right servo looking at it from the rear
channel 2 is the front servo
channel 3 is the throttle
channel 4 is the rudder
channel 5 is the remote gyro gain
channel 6 is the rear let servo
