Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 tracking problem.... please help!!!! >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 06-04-2007 | 07:56 PM
Default tracking problem.... please help!!!!
when the blade are out of whack.do you bring the higher blade back down to the other .or the lower blade up to the other blade.thank you for any help.
Old 06-04-2007 | 08:15 PM
Default RE: tracking problem.... please help!!!!
basically you figure out which one is closer to where it should be, and then track the other blade. mark the one you are adjusting so that you keep adjusting the same one after you spin it up
How you do that is unplug the motors and put the heli in normal mode at 0 throttle. The pitch should be right around 0, for some heli's it's slightly negative. The other way is to put the heli in idle up and 50% throttle and trim should be at 0 pitch. Whichever blade is closer, go with that one.
Old 06-04-2007 | 08:16 PM
Cjoker5475,
Normally your would bring the higer blade down to the lower blade. Kinda rule of thumb. However, what if the higher blade is set at the proper pitch. Then you would want to adjust the lower blade to the upper blade. Hmmmm, best thing to do is verify your pitch with a pitch gauge and go from there. BTW, what type heli do you have? If you have a Blade CP or CP Pro, and don't have a pitch gauge, you can do it by eye.. For safety, disconnect both motors from the 3n1 or 4n1 controller. Turn on TX and install battery into heli.
Wait for controller to arm.. Set throttle stick and throttle trim all the way down. Eyeball the tip of the blade with the paddle control frame and make it level with it. Mark the other blade with an X or a dot with a magic marker or something.. Disconnect battery. replug the main and tail motor. Plug in battery to heli. Wait for to controller arm.. Slowly spool up, and watch tracking, always adjust the blade with the X or dot on it, up or down. When you adjust that blade, if it gets worse, your turning the pitch control linkage the wrong way. Takes time to get use to this method, but it works fine. Eliminates the confusion factor.
Dave / Choppersrule
ORIGINAL: cjoker5475
