E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
is it possible??...
Old 08-25-2007 | 10:00 PM
Default is it possible??...
well i have a blade cpp, i have bl main w/ esc also, however the tail esc can't output enough amps for the dd tail to hold with the bl power. yes i know i can just get another tail esc, however, i'm kinda stuck cuz i got a rex right now and yes it's a dream to fly. i haven't flow the bcpp since i bought the rex, however, i'd thought if i can somehow harness that bl power and make the tail hold i might bust out the cpp again.
so i want to ask, since i already have a bl esc for the main, is it possible for me to connect the tail to the original brushed main esc?? and that to the hh gyro?? cuz basically i don't need the brushed main esc now that i have the bl esc. so if there's a possibility where i can harness teh power from the brushed main esc to power my tail, it'll hold indefinitely haha!.
and i dun think it's gonna burn out my tail because the tail motor will only pull as much as need to hold the tail.
is this possible?
Old 08-26-2007 | 09:16 AM
Default RE: is it possible??...
so i was thinking after i woke up...
connect the bl main directly to ch3,
connect throttle lead from 3 in 1 to my telebee hh gyro,
connect gyro to ch4,
leave rudder lead from 3 in 1 unplug,
power up in throttle hold and let tail (originally brushed main) esc initialize.
i hope i don't blow anything up lol!
Old 08-26-2007 | 12:44 PM
It's an interesting idea, the only problem I see is that in order to find its center, the gyro has to initialize with the rudder stick centered. And in order to initialize, the 3in1 main motor ESC has to be completely down, or 0% travel if you prefer. I don't know what it will do. I don't think you can hurt anything if you try it, though.
Georges
Old 08-26-2007 | 12:50 PM
thx, but i got it to work already!!! this is how:
connect main bl esc directly to ch3 on rx,
connect throttle lead from 3 in 1 to hh gyro,
y harness the hh gyro lead and the rudder lead from teh 3 in 1 to ch4,
y harness battery and bl esc to 3 in 1.
all in all you won't need anything extra if you have the bl system.
you'll need:
bl esc & motor,
1x y harness
1x jst connector y harness
taht is basically what you'll need just to run a bl system!!!
power up in throttle hold (or hold full left rudder) no it won't affect the hh gyro, (from test results anyways, haven't actually flown it yet)
