Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 Question about my CP Pro >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-30-2008 | 08:47 PM
Default Question about my CP Pro
I just purchased a CP Pro (used, two actually) and have begun playing around with it/them a bit. Anyway, on one of them, the rudder is reversed. If I push left, the tail swings right and vice versa. The other works as it should and uses the same radio. I will admit that I am a rookie. My only previous experience with heli's (or anything RC'd for that matter) is my Blade CX2. Thanks in advance.
Aaron
Old 01-30-2008 | 10:47 PM
sportrider_fz6's Avatar
Default RE: Question about my CP Pro
look at the radio, there are four switches at the bottom right corner one of them is labeled rud( the fourth switch) these are servo reverse, on mine the switched are set: ail= nor, ele=rev, thr=nor, RUD= rev. check and see how yours are set. my rudder was normal when I bought it I reversed it so the controls were the same as my CX2.
hope that helps!!!
Old 01-30-2008 | 11:03 PM
I will chech it when I get home from work. Thanks!
Old 01-30-2008 | 11:42 PM
your welcome!!!
