blade cx2 spin to left
1. Check your locking screws on the upper hub and mid locking collar.
2. Check for bent shafts.
3. Check Gearmesh.
4. Check your blades. Warped or bad blades will cause this.
5. Then reset your trim and porpotinal gain to the center.
More then half of the time it will be your blades. Make sure that you change and test different sets on the upper and lower.
Quattro1975’s Bents Shaft Repair
http://www.rcuniverse.com/forum/m_6791546/tm.htm
Gear Mesh Guide
http://www.rcheli411.com/pages/howto.php?howto=7&page=2
Eat2muchrice’s Warped blade test
http://youtube.com/watch?v=_7PwNTXOWMs
Eat2muchrice’s Blade boil fix
http://youtube.com/watch?v=RmNv8OlG6GQ
RCFEIND’s Balancing Blades
http://www.youtube.com/watch?v=15h9G...eature=related
If it still does this then change out your bearings, if its not your bearing then change motors. If you fix your problem and want to know more then check out this link.
Tips/Repair/Guides/Mods Links
http://www.rcuniverse.com/forum/m_68...tm.htm#6821632
Good Luck and fave fun.
3. Check Gearmesh.
Gear Mesh Guide
Hi
Does it turn slowly or fast?
Does it start off ok at the beginning of your flight and gradually get worse after a few minutes?
Did it fly fine originally and suddenly started doing this?
