E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
alloy main frame.
Old 03-10-2008 | 11:56 AM
Default alloy main frame.
Hi.
I've just got an alloy main frame http://www.ushobbysupply.com/product...roducts_id=530 bit confused as the screws supplied are not all correct. That problem I can get round.
What I would like to know is there are 3 brass washers, but nowhere for them to go. The check list shows them, but the instruction sheet doesnt.
Any idea where they go.?
Im wondering if they should go on the underside of the mainframe on the 3 screws securing the main tower shaft, or between the baseplate and the main tower shaft.
Any help would be great .
Thanks.
Old 03-10-2008 | 12:40 PM
Default RE: alloy main frame.
Phil,
i had one of those frames and I cannot tell you why they would supply the washers. I didn't have any with mine. I will say, however, this doesnt fit a CX. it's for a CX2 only. Although, with a few minor mods, I got it to work fine on my cx. Hope it helps a lil bit.
quattro
Old 03-10-2008 | 01:04 PM
Thanks for the info quattro1975
It is for a CX2 so no worries there.
More spares for my screw pot.
Old 03-10-2008 | 02:04 PM
Hi Phill86, i used mine on the servos when screwing to the maine frame .
