belt driven or gear driven tail rotor?
TN
i am hoping to have a new toy in not to distant future and i was wondering everyones opinions on belt driven tail rotors or gear driven? life span of the two and problems out of either versus how easy to fix or replace.
MI
a belt driven tail well last longer forsure
motor driven tails just work to hard and arnt very concestant
belt driven tails seem more stable as well
NE
Belt driven survives a crash and shaft gears don't. I have had bad luck with belts, so I prefer my shaft driven helis. I had a belt snap in flight and another one got shredded. I don't like feeding the belt through the boom and trying to get the belt tension just right. It is easier for me to get a shaft through the boom and set the gear mesh in a 1/4 of the time than I can with a belt. A beginner would probably be better off with a belt until they stop crashing as much, then go over to shaft drives if they want. You also don't have to worry about ESD and the temp affecting a shaft drive like you would on a belt. Either way helis fly great with a belt or a shaft.
Nick
Nick
