Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 Blade CPP2 tail motor problem >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 05-13-2010 | 12:55 AM
Default Blade CPP2 tail motor problem
<span class="Apple-style-span" style="font-family: Arial, Helvetica, sans-serif; font-size: 16px; border-collapse: collapse; -webkit-border-horizontal-spacing: 2px; -webkit-border-vertical-spacing: 2px; ">I have the Brushless upgrade and had it hovering tonight. Thought to myself, I can finally put that Huey body on it now. I go to zip it up and clean it all up and now the stupid tail motor won't work at all. I checked the connectors. Any ideas?</span>
Old 05-13-2010 | 07:44 AM
Steve's Avatar
My Feedback: (54)
Default RE: Blade CPP2 tail motor problem
Is the tail ESC arming?
Old 05-13-2010 | 08:25 AM
Yep, thought of that too, it got the solid green light.
Old 05-13-2010 | 09:00 AM
Have you hot wired the battery to the motor leads to see if it will spin up? Sounds like you may have a connection issue. My ESC would turn green and still not operate the tail motor right when it went out, so don't disclude it just because it gave the green light.
Old 05-13-2010 | 06:51 PM
I got it fixed today. It was a bad motor. Quite possible the person who soldered it held it on too long and damaged the insides.
Old 05-14-2010 | 01:26 PM
Thought it was fixed until I zip tied the bundle of wires again and it failed. After messing with it some more the wires to the gyro from the 2n1 came out. So I guess it will sit now until I can afford to get a 2n1. Anybody got a spare 2n1 laying around?
Old 05-14-2010 | 02:32 PM
I have one.....but it's for the CPP2 standard brushed motor.
Old 05-14-2010 | 03:11 PM
ORIGINAL: patryn
That is what I am looking for.
<br type="_moz" />
Old 05-14-2010 | 03:41 PM
I didn't think it hooked up to the gyro. Guess I should pay more attention to the wiring on my chopper, eh? Hahaha. Let me know if you want it. I saw your original post said you'd installed the brushless setup, which is why I didn't think you could use it.
Old 05-14-2010 | 04:18 PM
You still have to use the 2n1 for the brushed tail motor. PM sent
Old 05-14-2010 | 04:57 PM
Gotcha. I thought you had to swap out to the brushless 2in1. I'm still a noob at understanding which parts work where.</p>
Old 05-14-2010 | 07:05 PM
In a way, you do swap it out, but you still need it for the tail motor. You can go with a brushless tail motor, but you still have to have a separate esc.
