Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
switch help
Old 07-21-2009, 06:56 PM
handyman
Default switch help
i hook uo a swith from the speed control, i get all the servos but no motor, switch gos from the speed control to the rec, without the swich i get servos and motor, but with swich i only get servos,.....any ideas as to why its not working???????
Old 07-21-2009, 07:59 PM
Silent-AV8R
Silent-AV8R's Avatar
Default RE: switch help
Why are you putting a switch between the ESC and receiver?? What controller are you using?
Old 07-22-2009, 03:01 AM
WestCoastFlyer
No Switch. It's not the regular setup. Graphic courtesy of someone on RCU.
Handyman, edited to add: With electrics the "switch," on and off, is physically connecting the battery and disconnecting the battery.
Old 07-22-2009, 05:29 AM
handyman
for safety as to the prop being turned on when its not needed or putting the battery in, what i dont understand is why it will turn on and off the servos but no motor control, the motor will not run even if the servos do
Old 07-22-2009, 06:51 AM
BarracudaHockey
BarracudaHockey's Avatar
Because most switches don't have the signal wire which is what feeds the information to the the speed controller for throttle position. Infact most of them only open and close the power wire.
