Turnigy charging/balance plug question?
Is the Turnigy(5000/4s) balancing plug compatible with my Great Planes Triton EQ A/C D/C Charger? (Will use Dean Plugs). If not what do I use to Charge these batteries? Also is the Dynam SuperMate DC 6 Balance Charger compatible? (From Hobby Partz). Any information would be greatly appreciated especially on the balance plug compat. question. Thanks!
My Feedback: (325)
RE: Turnigy charging/balance plug question?
http://www.rcuniverse.com/forum/m_91...tm.htm#9116475 This may help
Guver: A lot of that was over my head. I need to know if the Supplied Balance Boards that come with Triton EQ wil work with the Turnigy Balance Plug. I'm pretty new to electric and it is a lot more involved and complicated then my glow planes were. If not compatible is their a board I can buy for use with the Trition? If not. what charger do I need? Thanks.
NY
It does not appear from looking at the manual that it includes a balance adapter for Turnigy batteries which use a JST-XH plug.
AZ
The Answer is yes! I use it right now. Remember though that you must plug in the balance plug and use the Dean at the same time. This is different than other charging systems.
