Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
using a seperate BEC
Old 06-24-2011 | 02:47 PM
My Feedback: (15)
Default using a seperate BEC
Hi Guys,
I want to buy an electric B-17 that uses 7 servos and has electric retracts that use lots of amps. I heard it is best to use a sperate BEC? Can someone please explane how this works and how to set it up? All of my electric flying has been done with small parkflyers and EDF`swhich had a esc. with 3amp bec, so I never had a need for a sperate BEC.
thanks,
Frank
Old 06-24-2011 | 03:10 PM
My Feedback: (12)
Default RE: using a seperate BEC
What size is your B-17 and whaat size servos?
Old 06-24-2011 | 03:29 PM
My Feedback: (15)
It is 1600mm WS with 7 micro servo and electric retracts , all made from foam around 5.5 lbs
Frank
Old 06-26-2011 | 02:52 AM
My Feedback: (15)
anyone???
Old 06-26-2011 | 03:02 AM
Banned
My Feedback: (9)
Question
I am setting up a model airplane to use an electric motor that will draw approx. 50 amps.The supplier provided a 60amp ESC and a seperate BEC. How do I hook the BEC up in this system?
Answer
Just connect the BEC to the battery and the output to the receiver battery port.
If the brushed motor ESC has a built in BEC ist must be disabled by disconnecting the red wire from the ESC to the receiver. The red pin can be removed from the ESC plug to the receiver and taped or the red wire can be cut and taped. Removing is the best/neatest solution.
That should do it.
Old 06-26-2011 | 10:27 AM
My Feedback: (15)
Thanks Red,
Is a sperate battery used for the BEC?
Frank
Old 06-26-2011 | 11:55 AM
Banned
My Feedback: (9)
ORIGINAL: skrez
Thanks Red,
Frank
No, you use the flight battery that powers the motors. If you are going to use a separate receiver/servo battery you don't need the BEC (Battery Eliminator Circuit) in the first place.
