Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Ground spinning
Old 11-27-2003 | 09:59 AM
My Feedback: (12)
Default Ground spinning
I tried to maiden flight my Super Miss the other day and I spent all the time on the ground trying to correct the HARD right turn it was making when I went to 1/2 throttle. This plane is a tail-dragger with a skid so no problem there. Each time the plane was getting air-speed it just went HARD right. No amount of rudder or trim would help the situation. Could this be a result of motor thrust . I'm using the AXI 2808/16 brushless with an elecktro carbon 8.5 x6 prop? I need some insight here. Thanks. Mikel-T HAPPY LEFTOVERS
Turkey sandwiches are made with MAYO! Miracle-whip is for Baloney.
Old 11-27-2003 | 12:57 PM
Default RE: Ground spinning
I have a Rascal I put an axi 2808/16 and had the same problem. It turned out to be one wheel was tighter than the other. When I fixed that it worked ok
Old 11-27-2003 | 06:15 PM
Use up elevator at the start of your run so that the tailwheel is forced down and works better. Let up on the elevator when the rudder becomes effective. Also, a lot of people use some tow out on the main wheels to help.
Chuck
Old 11-28-2003 | 05:29 PM
My Feedback: (12)
OK, Thanks guys I will try it with the wing off to see how she rolls. Thanks, mikel-t.
