Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Range Check
Old 04-29-2004 | 08:40 AM
BCB's Avatar
BCB
Default Range Check
Hello,
I just did a range check and got 64 yards with the antenna down is this good?
And could you look at the way I installed my antenna. I raped it around the tail skid with out crossing the wire in a coil then put some shrink-rap over it so I don't have to much wire flying out the back. Is this ok?
Thanks Brian.
Old 04-29-2004 | 11:50 AM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: Range Check
64 YARDS? That's plenty. Your radio's instruction manual will tell you that an adequate range check is 75 FEET, almost 1/3 of what you achieved
As long as you wrap the antenna in a coil, and don't bunch it up, you'll be okay. In fact, that was an excellent idea.
Old 04-29-2004 | 12:19 PM
BCB's Avatar
BCB
ORIGINAL: Matt Kirsch
Thanks Matt.
Brian.
Old 04-30-2004 | 10:20 PM
Jim Finn's Avatar
I always do a range check with the motor running. The motor controler often is the first to "jitter" so I set the transmitter down and walk away with the plane so if the motor ramps up I have a good hold of it.
Old 04-30-2004 | 10:36 PM
Rhilluk's Avatar
I have a field force 7 and only get 5m with the aerial down, anybody had problems like this before????
