hyperion 3007/30 25a esc??
i have a hyperion 3007/30 outrunner motor would it be ok for me to use a 25a esc with this motor??thanks
http://www.micronradiocontrol.co.uk/bldc.html
this is the 25a esc i am thinking of buying
My Feedback: (21)
RE: hyperion 3007/30 25a esc??
Sure, as long as you don't draw more than 25 Amps through the motor.
As a general rule, choose an ESC that's rated for AT LEAST as many Amps as the motor is rated for, unless you don't plan on running that many Amps through the motor.
Without more specifications on the motor, that's the best answer I can give.
