sourcing spur gears?
I would like to replace the nylon spur gears in two of my gearboxes and cannot find a source! Anyone know where to get them? I found clock makers are crazy enough to make their own gears, but i won't go that way
It has been a while since I asked that question. I wrote it when I was flying the Wattage planes 370 power setup Since then I have found two others. I used the MP Jet 5:1 gearbox and a speed 300. I also started buying, flying and becoming a fan of GWS airplanes. (edit) Forgot to add that I no longer have any broken gear problems. The MP Jet is sturdy as an ox (geared version) and the GWS just has the gear pop forward on a hard nose-in. No more broken gears
(/edit)
I have found several sources for gears, but all of them are more expensive than hobby sources. Still searching.
(/edit)I have found several sources for gears, but all of them are more expensive than hobby sources. Still searching.
My Feedback: (21)
Your original question was quite difficult to answer without specifying what gearbox you were talking about. Am I to understand that it was the Wattage 370 gearbox, such as on the Crazy Max? The only place I know of that might sell parts for those is Hobby People.
BTW, Wattage 370, Speed 300, and GWS 300 are all the same motor. I think that's why you like them so much
I was referring to spur gears in general, as in making my own gearboxes. The housing on the wattage box is not durable. When I went to the other types, I no longer had trouble with easily broken gears. With the price of the GWS systems, there is little motivation to make my own boxes.
I would still like a source of generic spur and pinion gears. I have a "Small parts" catalog, but the prices arent any better than Hobby People.
As for the motors, I specifically like the mabuchi 370 series because it is the best fit for an 8 cell 700 mAh AAA battery. The latest challenge is to find the best match for a 2 cell 1020 lipo battery. The GWS IPS and the GWS 100 series seems the most likely, but maybe the M100 is better....any opinions out there?
Also bought 20 2 cell batteries, 1500 mAh Li-ion. At 2.9 oz per set, the possibilities will much more limited.... I think. With the 3-4 amp limit, and the 2.9 oz...heh, not a good mix. Looking into the 2p2s or 3s2p with bigger motors. (The phone packs from etonic which has been posted. Great deals, honest transactions.
