how many cells can a 0.5 motor take?
AR
I've run an 05 on 10 cells before but not long enough to say the motor will hold up.
Go to
Motor Calculator
Go to
Motor Calculator
BC, CANADA
It depends on the particular motor. I run my MEC Turbo 10 GT (17 turns) on 10 cells. Also the MEC Turbo 10+ is a good 10 cell motor. The Kyosho Mad Science series -- Mag. Mayhem, Atomic Force, & Endoplasma run on 10 cells. You have to watch the amps the motor will draw, and you may have to up the gear ratio/lower the size of prop to keep the amperage in the usefull range. Most of these mentioned motors will run in the 30 - 40 amp range very well, but going higher may well damage the motor.
