Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
BECs - Elimination
Old 02-25-2006 | 11:35 PM
My Feedback: (9)
Default BECs - Elimination
I just bought a Great Planes 25Amp ESC that has a BEC circuit, and I would like to disable it , and use a seperate receiver pack, is it possible ??????
Thanks To All
joe1
I found my answer!
joe1
Old 02-26-2006 | 04:22 AM
Default RE: BECs - Elimination
yes, it is explained in detail in the instructions that came with the ESC
( this is from the instruction sheet that comes with the GreatPlanes ElectriFly Silver Series 25Amp ESC )
"Remove the red wire from the ESC's receiver plug. To do this use a small flat screwdriver to carefully raise the plastic tab holding the metal pin, Carefully pull the red wire out of the receiver plug and insulate the pin with heat-shrink tubing or electrical tape."
