ESC and Throttle EPA
I tried out a new ESC for the first time yesterday. Initially, I was disappointed as the Speed 400 motor wasn't developing much power. I found that increasing the transmitter's throttle channel end point adjustment to +125% (max on this Tx) gave much more power.
Tx - Hitec Prism 7x
Rx - Hitec Electron
Motor - Graupner Speed 400
Battery - 8.4V 600 mAH NiCD
ESC - GWS ICH-400
So, two questions:
1. Why did I need to run the EPA up to max?
2. How can I tell if the motor is now developing full power?
(BTW, this is my first model and first flight since 1987. This hobby sure has undergone some changes since then!)
Tx - Hitec Prism 7x
Rx - Hitec Electron
ESC - GWS ICH-400
So, two questions:
Thanks for responding, mkirsch.
>1. Perhaps the signal from the Prism 7X is different from typical radios.
Hmmm... you mean perhaps something is out of alignment? Maybe so. I dropped a note to Hitec about it.
>2. Remove the ESC from the motor and connect the motor directly to the battery.
Yep, reckon the direct approach is about the easiest way.
When I use an ESC from Dymond I only need half the stick to go from 0 to full throttle. The step size of the ESC may not be the same as the step size of the Tx.
If I have the throttle stick in the center point and turn on the ESC that becomes the 0 point and full is still full. If it is all the way down when I turn on the Tx the center point is now full. This is only with Dymond ECS's. Wattage, GP, Castle are different in that they use the full stick travel. I asked Helmut at Dymond about this and he said that the number of digital steps in the ESC's do not match the throttle stick on the Airtronics radio's.
Dru.
Dru.
