Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 HITEC  5065 digital servo problems ! >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 01-12-2009 | 11:16 PM
My Feedback: (29)
Default HITEC 5065 digital servo problems !
I recently purchased four of these servos (HS-5065MG) and there garbage. Two of the four are so weak they stall out just by touching the surfaces. They will seem to work on the ground , but get them in the air and watch out they will just stop as if stalled out. I found this out when my Sebart 30E katana would not respond. and felt very mushy. when I landed (first flight) I noticed the servos would barely move . and had no strength at all.
Any one else having problems with this servo????
Old 01-13-2009 | 07:42 AM
My Feedback: (31)
Default RE: Anyone else having problems with HS 5065MG servos ??
wow what are the specs on those beast?
Old 01-13-2009 | 12:02 PM
My Feedback: (29)
Motor Type: 3-pole
Bearing Type: Top BB
Speed: 0.14 / 0.11 sec @ 60 deg.
English Metric
Torque: 25 / 31 oz./in. (4.8v/6v) 1.8 / 2.2 kg.cm
Size: 0.92" x 0.45" x 0.94" 23.60 x 11.60 x 24.00mm
Weight: 0.42oz 11.90g
Old 01-13-2009 | 12:46 PM
My Feedback: (31)
those are pretty low on the oz spec so i think they are performing to what they are capable of......
Old 01-13-2009 | 12:56 PM
My Feedback: (29)
actually there not ok . if a digital servo is rated at 31oz and 4 oz will stall it something is wrong, and your NOT getting what you paid for. you need to keep in mind it's on a 40oz plane
Old 01-13-2009 | 01:02 PM
My Feedback: (31)
Are you running this on 6 volts battery?
Is this plane a park flyer?
Old 01-13-2009 | 01:09 PM
My Feedback: (29)
it's running on an electric plane. with a seperate bec programmed for 6v. i'm on hold with horizon now hoping they will make them good
the plane runs on 4s 2600 LIPO's 16.8 volts
Old 01-13-2009 | 02:11 PM
With Horizon ??????
I know they distribute some HiTec servos but isn't the the real warranty source Mike Mayberry at Hitec RCD USA, Inc. in Poway, CA as they represent HiTec ___ The Factory ___?.
No criticism intended it simply seems like the long way around.
Old 01-13-2009 | 02:44 PM
My Feedback: (29)
your correct. When I finally got someone on the phone . that's what they told me as well. I called Hitec and they admited to seeing some problems with this servo . They asked me to send in my brand new servos for maybe a month, and they will repair them. I have tried to return them to the LHS and they refused. I'm sorry but this sucks!!!! I paid $200.00 with tax for (4) brand new servos and now my only option is to send them back for a month.
do not buy these pieces of garbage!!!!!!!!!!
Old 01-13-2009 | 04:41 PM
While I have never used HiTec equipment I have read much about their service levels and what you describe is the opposite of that which I have read.
Go here: http://www.rcuniverse.com/forum/pmse...?toMemId=24473
And email Mike Mayberry directly.
I'm guessing that Mike's response will be quite different from that which you have received.
Old 01-13-2009 | 10:52 PM
My Feedback: (29)
Pm sent to Mike I have been searching for other threads or comments concerning this servo problem, and on runrider there are a few people having the same problem as well.
surely someone on RCU is having problems with them
Old 01-14-2009 | 12:14 PM
Based upon your experience and the Run-Ryder aspect it would seem to be a lead pipe cinch.
Old 01-14-2009 | 03:09 PM
My Feedback: (29)
Default RE: HITEC 5065 digital servo problems !
It's a new product, that still has some bugs to be worked out. I think they should have offered to swap them out. and not make me wait for the autopsy report. lol
Old 01-16-2009 | 12:55 PM
cyclops2's Avatar
I had my fill of Hi Tec over 6 of 10 surface radios failing within 15 minutes of use. Their solution. I did something wrong. Crap.
They were for a childrens program. I had at that time 6 other radios with no failures.
Their Featherlie receivers were factory rejects also. "Being to rough plugging in and removing the channel plugs." More crap.
I do not got to bed with the same snake 3 times.
Old 01-16-2009 | 01:00 PM
cyclops2's Avatar
Mandtra.
If you paid by a credit card. Call the CC company and tell them you want your money back from Hi Tec. They WILL normally go along with a refund in such out right fraud. You still got nailed for shipping & insurance by HI Tec ?
Old 01-16-2009 | 01:27 PM
My Feedback: (29)
yes i paid to ship the servos back to Hitec. i would not be surprised though, if they say nothing is wrong with them. they will work for a few minutes before they get hot and quit. this is not ny first problem with Hitec . I had a problem with a Multiplex charger and they would not do anything about it either. and Horizon my brand new JR 9103 2.4 TX went out on me last month and I had to pay to have it fixed as well. I have no faith in any of these guys. well DA has been good to me. Sorry to be so negative , but I do not forget easily when I get screwed
Old 01-16-2009 | 05:38 PM
cyclops2's Avatar
I just tell the truth about bad deals I have had with hobby companies at parties.
Heck. I just like treating a company the way they treat me.
Old 01-20-2009 | 06:00 PM
mandtra
Any word from Mike?????
Old 01-26-2009 | 11:20 PM
My Feedback: (29)
onewasp: He sent me a PM and said about the same thing as they did on the phone. and gave me a number to call if i wanted. I did not call. I sent them off over a week ago and still waiting to hear something . I will post as soon as I hear something.
Old 02-04-2009 | 07:03 PM
My Feedback: (29)
It has been almost three weeks now and still no reply. I have sent mike two more Pm's and no reply. Maybe he's on vacation ?
Old 02-05-2009 | 07:50 PM
ORIGINAL: mandtra
You are certainly giving him the benefit of the doubt.
However, if you will go to post #5 here: http://www.rcgroups.com/forums/showthread.php?t=995842
It indicates that he answered posts on RCG today!
Doesn't do much for bolstering your opinion on HiTec does it?
