Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Comparable Motor System
Old 02-15-2010 | 10:00 PM
Default Comparable Motor System
Hello,
I have just aquired a vintage Leisure Electronics American Eaglet kit. I built one many years ago when the choice power system was the then available Leisure geared 05 motor and 7 cell 800 mah NiCad battery. I know that this is a dinosaur by todays standards. I would like to power this new model with a modern brushless/LiPo set up. I need some suggestions from more experienced modelers as to what would be comparable to the older power system. Any suggestions would be welcome. Thank you.
Steve Z
Old 02-17-2010 | 02:57 PM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: Comparable Motor System
You don't want comparable. That would be a true let-down.
What you want is "adequate" even "excessive" power.
Can you provide some specs on the plane? Maybe some pics?
How's the room in the cowl area? Is it tight or do you think maybe an outrunner will fit?
Old 02-24-2010 | 10:26 PM
Here are the specs on the plane.
Span-64 inches
Weight- 41 0z
Wing Loading-10.4 0z per sq ft
Wing Area-571 sq in
Bear in mind that the weight was probably calculated with the heavy primitive setup and then available mini servos. Also, a separate Rx battery was required and a servo for "on/off" operation. I would guess that by today's standards, the plane would weigh no more than 35 oz. I believe an outrunner would work under the cowl. I would like some input as to either style, inrunner or outrunner. The selected electric prop would be an 11 x 7. Thank you!
Steve Z
