Sukhoi Su-26M BNF by ParkZone
#1126
My Feedback: (20)
RE: Sukhoi Su-26M BNF by ParkZone
ORIGINAL: Wheelnut
Then you are going to pay at least twice the price for parts from the LHS for parts. That is were they really make their money.
When I got my first Exceed J-3 Cub 36'' wing span, I bought two of them for the price of one PZ J3-cub. So I had all the spare parts I needed. I upgraded it to brushless with HC parts for less than $30.00 including shipping.
and for the planes listed, there really is no real comparison between the two planes
one has a 34" span the better has a 44" span, and that alone parts will be more
and again I agree the parts at your local HS is way over priced!
#1128
CA
A flight report from yesterday. I got the SU-26micro out and moved my rudder linkage to the closest hole, for maximum throw. Then since I was there I did the elevator as well . I have somehow gotten used to full throws on both the 4-site and the Sukhoi, and figured that I might as well get all the deflection I could.
At the same time I am flying these little batteries from HC, 160mah 30C, and they are fast. And they allow me to go fast enough to spit batteries in fast rolls or fast loops . So out I go with the plane with the switches in low and give it a toss. I hit the throttle and pull up and roll a couple of times, not slowing the 60* climb. Then I took a couple of laps to get some airspeed and just threw the plane around like it was a 1 meter size plane. I flipped the switches after the first set of rolls and loops. The amazing thing is that I now have some rudder authority . I could get the tail to visibly corkscew in a roll . I brought it in on the timer and found a new problem. I had to relearn how to land. That took a couple of passes, but I think it lands better in this configuration more control and better power.
Now some of you might be wondering if I messed with the ailerons. For this plane that requires surgery. Said surgery has been done and I will fly the plane on full everything as soon as I can.
Fern
I just got in a flight before the storm arrives, and noted that full rates are...85%, I will do something about that . This time I was not doing an "abuse the battery" flight, but a check flight. I will probably end the abusive flights. The plane was just as fun without the battery busting full throttle full time. The extra aileron made for much quicker and precise response. The roll rate was quicker, but not as fast as I thought it would be [X(]. With the new batteries, and the comfort in the High rates, this is a different airplane than the one I bought back when. And much more fun [X(]
Fern
Fern
Fern
#1130
CA
Your welcome. I know that mine is a third generation M model, but I hope that the stuff in the XP model is as fun.
Fern
Fern
#1133
CA
I have the bigger battery bay(2), and it had a smoking motor out of the box(3). I thought that I had m2 until posts indicated otherwise.
Fern
Fern
#1134
CA
Here is a vid of everything maxed, http://www.badiusownersclub.com/vide...20mar%2010.wmv
The plane is a conduit to your thumbs.
Fern
Fern
#1135
CA
So how is this plane for a second plane? I just learned how to fly my J-3 and looking for a next plane. I see the xp version of this one but cant tell to much of a difference? Is it mainly just some added power?
#1138
PA
What about changing the motor out. Is there a difference between the Sukhoi and P-51 or 4-site motor? Or are they just geared differently? What about adding a micro brushless motor and speed control? I thought I saw something on the H.K. website that would work.
#1139
LA
Guys, the shaft is bent from nosing down to hard. I ordered a couple of shafts. I looked on the forum but i can`t find out how to remove the gear from the shaft. Thanks
#1141
QC, CANADA
ORIGINAL: FERNDALE AIR FORCE
On the other side, wow did I spit of lot of them with the PZ Mustang! Got tired of that and replaced the velcro yesterday, but didn't had a chance to try the new velcro yet. I'm also bending the wings a lot more since they do allow you to pull more Gs... You can loop, and loop, and loop, and yank the battery! I guess that's a good thing Luckily, both planes still fly quite well with the battery hanging out. (Bit worst on the 4-Site since it does get tangled in the wing...
#1143
CA
I made a new battery pouch and put the velcro on sideways, guaranteed a good bond everytime, and I can use the batteries in the msr as well. I wonder what it would do to an mcx or a vapor?
Has anyone tried the original prop with the better motors and batteries?
Fern
Fern
#1144
QC, CANADA
A friend of mine flew a Blade mSR outside yesterday, with a 160mah in it. Wow this thing can go HIGH and far. At some point, I could not tell if he was coming or going... There was no wind at all. This thing is awesome under any roof (even a small room), but somehow, it's almost boring when you can fly it that far or that high. Didn't time the flight though, but sure enough, it was longer than usual, even if my friend was gunning it all the time.
#1145
CA
#1146
CA
So I had a recent mid air disaster, that left the cowl torn up and the entire gearbox mounting area and the gearbox hors de combat. Ok, what happened is I was flying in a trough between 2 storm fronts, and the wind was less than predictable. And when I should have pulled the nose up to ride the wave, the nose was a touch down and I got driven into a roof rather dramatically.
I had a temporary form of PTSD and considered just buying a new one. I fought this off, although for $70 it was tough. Yesterday, I chose to see about repairing the plane as the second storm had left us with 20-30 mph winds[X(] . So I did fix the plane, and I hope to get to fly it in a while or tomorrow.
What? Pics? OK pics.
Fern
Fern
#1147
OUCH Fern!
Have some wind shear where I fly( a hole in the woods) and sometimes when the wind hits just right there just is not anything the pilot can do!!!
I have been using the TX that came with the P-51 until the other day when a friend gave me 2 TX both from P-51s.
I put one of them to use on the SU-26 and the airplane immediately became 100% easier to fly.
Seems that the TXs may vary in quality.
#1148
QC, CANADA
#1150
CA
Supertiga, there is a way to re-calibrate those controllers. Here is the link, http://www.rcgroups.com/forums/showt...t=re+calibrate.
I have some new fuses on the way. One will go brushless, that gear is on the way as well, the other will stay brushed. Should make for a valid test.
Fern
Fern
