Prop question
TX
Hello
Ihave a falcon prop 20.5 x 14.5 on the way and was about to order a true turn spinner for it but they don'thave the slot sizeon file. Is there an apc that is similar so I tell them to do the slot that size. I don't want tohave to dremel the spinner after I get it.
Happy landings.
Happy landings.
ORIGINAL: g_mkoch
Hello
Happy landings.
Hello
Happy landings.
BTW:tru-turn offers "TurboCool"spinners that include cooling holes. They are available but the web site may not be updated to show them. Call Tru-Turn to order.
My Feedback: (46)
NJ
ORIGINAL: g_mkoch
Hello
I have a falcon prop 20.5 x 14.5 on the way and was about to order a true turn spinner for it but they don't have the slot size on file. Is there an apc that is similar so I tell them to do the slot that size. I don't want to have to dremel the spinner after I get it.
Happy landings.
Hello
Happy landings.
TX
Does anyone know the thickness of the prop hub and a falcon 20.5X14.5? Also what size of prop shaft does it come drilled for 6mm, 8mm or what?
Happy Landings
Happy Landings
TX
ORIGINAL: J Lachowski
Drilled for 8 mm
Hub thickness quick measurement with a ruler, approximately 9/16"
Drilled for 8 mm
