RX Lipo C rating?
Is the C rating of a RX battery important?
I have a 2 cell lipo for my RX battery 1600 mah and a 35C rating. Goes to my Regulator then on to the RX
Wasn't sure if C rating is critical or not for RX pack
Thanks in advance
Thanks in advance
Forgot to mention I'm a newb
I have no clue what you mean
I just want to make sure what I have wont damage my switch/RX It's a Power Box switch/reg
NY
ORIGINAL: lablover
Thanks in advance
Thanks in advance
If you are running this on an electric model, however, you won't need a 1600 mAh Rx battery. 800-900mAh is plenty. Depending on your flying style and the pattern sequence you fly, typically 25 to 50 mAh is consumed per flight.
