ESC question
TX
Hi
I'm planning on using a Q80 14XS on my next project, but can't decide which ESC to go with. what would be better option Master Mezon 95 or Master Spin 99 Pro?
Happy Landings
Happy Landings
The problem will be getting one I can't find one anywhere in the US. I would like a Spin Pro 77 or 99 but no luck.
Anyone have a good used Spin or Spin Pro they would part with ?
Thanks Kirk
Thanks Kirk
My Feedback: (45)
The Mezon is the new line of controllers that were designed for the newer Hacker motors. The Spin's work fine, but the Mezon's right now are as nice an ESC as I've seen. I use the Mezon 90 and love the BEC feature that is built in as it gives me redundancy without any special equipment. Very easy to program and is very smooth.
Arch
Arch
My Feedback: (41)
For what it's worth my Wind S Pro has the 99, but it will get replaced by the Mezon Arch is talking about along with a new Q80-13XS when my friend who still has his shop gets around to it... lol
You MAY want to consider the Mezon if you can get it?
Mezon is great. I have a Jeti xmitter, too, and telemetry is set up to that the xmitter speaks the mAh at regular intervals. Also, I can see the battery voltage at the start of a flight, so if I were to put in a battery that is not charged, I can tell right away.
My Feedback: (8)
The Jet Mezon 90 and 90 lite are less expensive than the Hacker version of the controller and are both in stock here. Spin 99 right now a little tough to find unfortunately right now. Hopefully there will be more soon.
Jim O
