Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Allure by Bryan Hebert
Old 03-15-2015, 08:36 PM
  #251
MAVROS
I wish I have the time to practice Jason .......nowhere good enough mate ...last time I competed was when the curare and dirty birdi were in fassion
rgds
Mavros
Old 03-15-2015, 08:40 PM
  #252
Jason Arnold
Jason Arnold's Avatar
rgds
Mavros
That's a while ago. Things have moved on heaps since then.
We have an event at Wingham the week after the NATS. Perhaps come up for the day?
Cheers,
Jason.
Old 03-15-2015, 08:49 PM
  #253
MAVROS
Thanks for the invo see how I go....
Mavros
Old 03-16-2015, 12:30 AM
  #254
ewan
Originally Posted by Jason Arnold
Allure vs Escence... Which is bigger?
Hi Jason,
You will soon find these are normal size, the rest are just smaller!
Ewan
Old 03-16-2015, 06:25 PM
  #255
Jason Arnold
Originally Posted by ewan
Hi Jason,
Ewan
This is right Ewan, would be interesting to stick a .60ci Pattern model next to and Allure or Essence....
Last night the stab servo trays were glued into position and one BLS153 was mounted. With NMP Dual Axis Ball Ends and CK Aero control horns the linkage needs to be 82mm long. Again, the pivot point is ahead of the hinge line and the horns are the 17mm version.
Cheers,
Jason.
ID:	2081929   Click image for larger version
ID:	2081930   Click image for larger version
Old 03-17-2015, 11:31 AM
  #256
Jason Arnold
Photos with the servo and horn fitted.
Cheers,
Jason.
ID:	2082077   Click image for larger version
Old 03-17-2015, 12:01 PM
  #257
Jason Arnold
Here are some photos of the Custom scheme Bryan did for Brett's 2015 WC Allure. Nice!
ID:	2082082   Click image for larger version
Old 03-17-2015, 06:47 PM
  #258
Jeff Worsham
My Feedback: (28)
Like that scheme - a lot!
Old 03-18-2015, 07:39 AM
  #259
smcharg
smcharg's Avatar
Default Exhaust Vents
Jason had contacted me yesterday concerning cooling exhaust vents that we placed in the Contra Allure prototype. I have included a few pictures to show the placement of the vents on the bottom of the aircraft. Keep in mind, the Contra prototype has a removable chin cowl where the production Contra Allure does not. This may affect where you decide to place the vents. The most important thing is that your "exhaust" volume is twice that of your "intake". This creates a good airflow. Although I haven't seen a real-life production model yet, I've seen a few pictures and Jason told me that the holes were already there in the cheek cowls for exhaust. The attached pictures are simply of the bottom from the nose looking back. Please excuse the mess on the work table
ID:	2082267   Click image for larger version
ID:	2082268   Click image for larger version
ID:	2082269   Click image for larger version
Old 03-18-2015, 10:13 AM
  #260
Portlandflyer
You call that a mess? You don't know mess!
Old 03-18-2015, 12:07 PM
  #261
Jet Katt
Simply Awesome....there are no other words to describe it. Both Allure paint schemes in posts #228 and #257 are just awesome! Bryan/Brett this is creative genius at its finest...keep up the good work.
Old 03-18-2015, 12:32 PM
  #262
Jason Arnold
Hey Scott,
Thanks for posting the pictures mate. Your bench looks spotless compared to my shop at the moment.
I believe these cooling holes or something similar will be done in the factory for future deliveries. Correct me if I'm wrong Bryan.
The stab servo cut-outs will also be done in the factory for future deliveries.
Cheers,
Jason.
Old 03-18-2015, 03:30 PM
  #263
ltc
Cheers,
Jason.
Pardon me for asking what may be a stupid question, but why is the pivot point ahead of the hinge line?
I always thought the pivot point was to be placed on the hinge (center) line.
Thank you very much.
Old 03-18-2015, 04:34 PM
  #264
Jason Arnold
Hi ITC,
It’s not a stupid question at all. When I did the aileron horns, I assumed the pivot point needed to be right over the hinge line. I sent a picture of what I had done to Bryan and that’s when I was advised the front edge of the horn needed to be right on the edge of the aileron bevel. Bryan advises that his CK Aero control horns were designed in a control linkage program to have perfect setup for equal travel up and down when mounted on the edge of the aileron.
Cheers,
Jason.
Old 03-18-2015, 11:48 PM
  #265
serious power
Hi ITC,
Cheers,
Jason.
Hi Jason,
Would that not depend on the depth of the bevel - ie ; the distance from 'the edge' to the hinge pivot ??
The control attachment looks very far forward on the elevator above - might be camera angle !?
Relative heights are also in play - eg; a sunken elevator servo horn V a raised one like yours (think tangents).
Brian
PS ; I really like the WC scheme - I think it's great on a lot of levels - a bigger file version of the photos would be good ! The switch in canopy colour also works very well.
Old 03-18-2015, 11:58 PM
  #266
serious power
Double post sorry - RCU ??
Old 03-19-2015, 12:44 AM
  #267
MAVROS
Hey Jason can you give us a side view of the WC 2015 colour scheme...it looks pretty good mate
rgds
Mavros
Old 03-19-2015, 09:36 AM
  #268
smcharg
smcharg's Avatar
Here's a profile shot of the WC Allure.
Old 03-19-2015, 04:06 PM
  #269
Jason Arnold
Originally Posted by serious power
Hi Jason,
Brian
Hi Brian,
There are probably a number of factors that may influence the position of the horns. I'm happy to go with with what Bryan advises though.... The pictures probably exaggerate things a little. This photo is probably better. The pivot point is less than 1/4" forward of the hinge line.
Ralph has finished my CRS mount too. Looks real nice.
Interestingly, Ralph uses a ply firewall to reduce noise.
Cheers,
Jason.
ID:	2082574   Click image for larger version
ID:	2082575   Click image for larger version
ID:	2082576   Click image for larger version
Old 03-19-2015, 04:49 PM
  #270
serious power
Hi Jason,
I meant the tail/elevator in post 256 - sorry I should have said.
Brian
Old 03-19-2015, 06:25 PM
  #271
Jason Arnold
Hi Jason,
Brian
Hi Brian,
I don't have a better shot of the stab horns ATM. The current picture is taken from behind so it woul not give a true indication of the pivot point relative to the hinge line.
Cheers,
Jason.
Old 03-20-2015, 12:40 AM
  #272
serious power
Hi Jason,
Ah, ok.
Elevators need different travel up and down anyway - so once you get both exactly the same (pivot V hinge line) you will get it from the radio anyway.
However I would align to the hinge line or for under-slung elevator controls (they nearly all are) perhaps have the control pivot behind the hinge line as you will need more down travel than up.
Exactly the same is of most importance.
Best of luck with it.
Brian
Old 03-20-2015, 12:47 PM
  #273
JerMilosek
Jason,
Is your motor mount adjustable for left/right, up/down thrust angles?
Kudos to Ralph, he does quality work.
Looking forward to your maiden, J e r
Old 03-20-2015, 01:13 PM
  #274
Jason Arnold
Originally Posted by JerMilosek
Jason,
Hi Jer,
Ralphs mount is adjustable with shims or washers. He is providing some ply spacers with my mount to make it suitable for V1, V2 & V3 Brenner Contra drive systems. Previously, his mount was only available for the Hacker C50 motor but now Neu is available. I agree, the his work does look first class.
Looking forward to the maiden myself.
Cheers,
Jason.
Old 03-26-2015, 11:58 AM
  #275
Jason Arnold
Hi Guys,
Yesterday the CRS mount, linkages and some other trick items arrived from Ralph Schweizer of Austria. Very nice gear of the highest quality!
Some real progress can be made now...
Cheers,
Jason.
ID:	2084293   Click image for larger version
