Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Allure by Bryan Hebert
Old 07-10-2017, 12:52 PM
  #726
Jason Arnold
Jason Arnold's Avatar
Default Nearly there....
All the tedious tasks are now done.
1. All surfaces have been hinged.
2. Elevator extension cables made.
3. RX and RX Battery trays mounted to fuse.
4. Battery/ESC tray completed and mounted.
5. Elevator servos fitted along with Control horns and linkages.
6. Carbon stab incidence pin glued into the fuse. Important step. You do NOT want any slop here.
7. Elevator servo extensions run in fuse paper tube. About 1.5" had to be cut off the paper tube in the fin.
8. Stabs mounted to the fuse.
There's just a few more small tasks left to do and then it's time to program the JETI DC-24.
Cheers,
Jason.
ID:	2224024   Click image for larger version
ID:	2224025   Click image for larger version
ID:	2224026   Click image for larger version
ID:	2224027   Click image for larger version
ID:	2224028   Click image for larger version
ID:	2224029   Click image for larger version
ID:	2224030   Click image for larger version
ID:	2224032   Click image for larger version
ID:	2224033   Click image for larger version
ID:	2224034   Click image for larger version
ID:	2224035   Click image for larger version
ID:	2224036   Click image for larger version
ID:	2224037   Click image for larger version
ID:	2224038   Click image for larger version
ID:	2224040   Click image for larger version
Old 07-12-2017, 01:33 AM
  #727
bem
Hi Jason,
When You have time could You tell us little more about the battery tray solution You made. The thinking behind the design, weight, function etc.
/Bo
Old 07-12-2017, 01:20 PM
  #728
Jason Arnold
Default Battery Tray
Originally Posted by bem
Hi Jason,
/Bo
Hi Bo,
The thinking behind the battery tray was to provide a larger range of adjustment for different weight packs and eliminate Velcro straps. It also incorporates the ESC mount under the front which makes the whole assembly modular and easily removable from the model. This tray design is an evolution of previous designs which were all cut by hand. The CNC machine opens up new possibilities in this respect.
The main plate is secure to the fuse with six 100mm cable ties and two slots at the front. The battery plates can move up and down the main plate which provides quite a big range of adjustment. I have found that moving between a 485 gram pack to 600 gram pack results in a mounting difference of about 1 1/4" to maintain the same CG.
The weight is somewhat more than expected at 117 grams complete. The weight estimates in Fusion 360 must be slightly out... The main plate and ESC plate weigh about 36 grams which is reasonable. Anyway, this is a prototype so weight savings are definitely possible. For starters, the battery plates and clamp could be made out of 1mm Carbon instead of 2 and 1.5mm respectively. The structure as it stands is very rigid. Thinner material and more lightening holes will reduce the weight to good levels.
Cheers,
Jason.
Old 07-13-2017, 12:47 PM
  #729
Jason Arnold
Default Aileron Horns
The aileron horns have now been glued in with 30 minute epoxy although in this cold weather, its probably closer to two hours or more.
Tonight I'll cut some 2.5mm Titanium to make up the linkages. Then the wiring and soldering party commences.
Cheers,
Jason.
ID:	2224275   Click image for larger version
ID:	2224276   Click image for larger version
ID:	2224277   Click image for larger version
Old 07-16-2017, 01:00 PM
  #730
Jason Arnold
Default Maiden Flight Complete
After many late nights and long days in the shed, my Allure Builders kit has finally flown. This is a whole new model, radio and contra. I'm glad that I did a range check and pre-flight check before the maiden. My Ailerons were reversed! That could have got messy!
Anyway, the model flew nicely out of the box so to speak. It flys straight and is very close to what my previous Allure ARF was. Slight pull to the belly in both KE (stab inc is right) and slight pull to the canopy in the downline. The upline has no pull.
Not sure what the final weight is yet but will get her on the scales sometime this week.
Cheers,
Jason.
ID:	2224601   Click image for larger version
ID:	2224602   Click image for larger version
ID:	2224603   Click image for larger version
ID:	2224604   Click image for larger version
ID:	2224605   Click image for larger version
ID:	2224606   Click image for larger version
ID:	2224607   Click image for larger version
Old 07-18-2017, 12:53 PM
  #731
Jason Arnold
Default The Weigh In......
Last night I put the Allure with built-up wings and stabs on the digital scales. Without flight batteries, the total weight was 3,577 grams. With Hacker TopFuel 4600 batteries the RTF weight is 4,574 grams. I'm very happy with this weight. 🙂
Old 07-23-2017, 11:02 PM
  #732
Jason Arnold
Default ESC Cooling Holes
In my haste to get the new Allure in the air last weekend, I neglected to cut some holes up front for cooling the ESC. Given the ambient temperature is low in Sydney this time of year it was not considered a big issue. However, the ESC did get a little hot regardless so some ventilation holes were cut on Saturday. The ESC now barely gets warm after a P17 flight.
The trimming process is progressing well too. The upline is dead straight and a small down elevator to low throttle mix has been added. Knife edge has a small pull to the belly in both directions so the CG will be moved a fraction more forward.
Cheers,
Jason.
ID:	2225400   Click image for larger version
Old 08-13-2017, 07:01 AM
  #733
DRC1
My Feedback: (10)
Selling my Allure on RCU...
Click Here for RCU Listing
