Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Allure by Bryan Hebert
Old 12-22-2016, 04:58 PM
  #626
ltc
Originally Posted by Jason Arnold
Hi ITC,
There's no particular reason for using different adjusters. Hamish Galloway used the same adjusters in his model and I had them in the shed. The standard steel hardware will be swapped out for titanium and aluminium equivalents to save a few extra grams too.
BTW, the front adjusters are off an old BJ Craft model and the rear ones are from Hobby King. They call them "widgets".
Cheers,
Jason.
OK, thanks.
I assume you are using both front and rear adjusters?
I have the metal ones. For some strange reason, they are in their Boat department/section on the Hobbyking website? I assume to hold a propellor shaft?
https://hobbyking.com/en_us/adjustab...haft-pair.html
They are also available here in the USA from F3AUnlimited
http://www.f3aunlimited.com/gwa8mm
Old 12-22-2016, 05:22 PM
  #627
Jason Arnold
Jason Arnold's Avatar
Originally Posted by ltc
OK, thanks.
Yes ITC, I'll be using the widgets on the rear anti-rotation pin and the BJ craft type on the front. I wouldn't regard the BJ units as being totally suitable for the back.
Cheers,
Jason.
Old 12-27-2016, 03:42 PM
  #628
Jason Arnold
A little bit of work on the CNC Router (adjuster plates) and the Allure builders kit over the last couple of days. Stabs are now ready for prep/film and the new control horns fit well. MKS Servos are being used throughout this model. In the stabs we'll have DS9660A+ (pictured). The wings will have BLS 950's and a HV1220 will shift the rudder.
Today the wing adjuster plates will be glued to the fuse sides and the control horns will be fitted to the Ailerons.
ID:	2194576   Click image for larger version
ID:	2194577   Click image for larger version
ID:	2194578   Click image for larger version
ID:	2194579   Click image for larger version
ID:	2194580   Click image for larger version
ID:	2194581   Click image for larger version
ID:	2194582   Click image for larger version
ID:	2194584   Click image for larger version
ID:	2194585   Click image for larger version
ID:	2194586   Click image for larger version
ID:	2194587   Click image for larger version
ID:	2194588   Click image for larger version
ID:	2194589   Click image for larger version
ID:	2194590   Click image for larger version
ID:	2194592   Click image for larger version
ID:	2194593   Click image for larger version
ID:	2194594   Click image for larger version
ID:	2194595   Click image for larger version
ID:	2194596   Click image for larger version
ID:	2194597   Click image for larger version
Old 12-27-2016, 04:14 PM
  #629
drac1
drac1's Avatar
[h=2]Message[/h]Invalid Attachment specified. If you followed a valid link, please notify the administrator
Old 01-09-2017, 03:17 AM
  #630
Jason Arnold
The covering process has begun.
Cheers,
Jason.
ID:	2196067   Click image for larger version
ID:	2196068   Click image for larger version
ID:	2196069   Click image for larger version
ID:	2196070   Click image for larger version
ID:	2196071   Click image for larger version
ID:	2196072   Click image for larger version
ID:	2196073   Click image for larger version
ID:	2196075   Click image for larger version
Old 01-09-2017, 06:12 AM
  #631
Stuart Chale
Jason what are you using for covering? And are you applying both colors before finishing the edges on the bottom of the elevator? Can you explain your technique?
Old 01-09-2017, 11:51 AM
  #632
Jason Arnold
The covering is the "Luxurious" Hobby King brand. ;-)
Both colours are applied to the flat surface first one at a time and then rolled around the edges etc as one piece. I am by no means an expert on covering. In fact, this is my first real covering job. I have however been talking to the likes of Hamish Galloway & Chris Swain for help on how to do the job and importantly on the surface preparation before covering is actually applied. The balsa was finished off with 1200 wet & dry paper along with compressed air and a tack rag.
Cheers,
Jason.
Last edited by Jason Arnold; 01-09-2017 at 12:23 PM. Reason: Added extra credits and info.
Old 01-10-2017, 05:01 AM
  #633
Stuart Chale
Always looking for different ideas to make covering easier or better 1200? You got me beat, I stop at 600
Old 01-10-2017, 05:20 AM
  #634
serious power
Hi,
I'd stop at 400 for film covering.
600 pre and after primer if painting.
1200 pre clear coat !
Clean dust free surface is key - I use a vacuum cleaner c/w vigorous brushing towards to nozzle. Reduces airborne dust.
Covering in a different room/area to where the balsa sanding is helpful also as removing the backing from the covering produces a lot of static - a dust magnet !!
Brian
Old 01-10-2017, 12:58 PM
  #635
Jason Arnold
Originally Posted by serious power
Hi,
Brian
Hi Brian,
I did some test pieces with hairspray and different levels of sanding. I found that wiping down with methylated spirits between levels of paper and compressed air and a tack rag gave the best adhesion. It's like the covering has more surface area to stick to because the surface is flatter and clean.
Anyway, half a stab is now covered. The top side is next.....
Cheers,
Jason.
ID:	2196246   Click image for larger version
ID:	2196247   Click image for larger version
Old 01-10-2017, 01:03 PM
  #636
Jason Arnold
I went 400, 800 and then 1200 grade. Between each sanding the whole stab was wiped down with a clean rag soaked in methylated spirits. This makes the grain stand up to some extent.
Often with covering you can see a lot of grain through the covering. After sanding with 1200 I have to say the grain is minimal.
As with everything, preparation, preparation, preparation.....
Cheers,
Jason.
Old 01-12-2017, 10:53 AM
  #637
kenh3497
kenh3497's Avatar
I have in the past applied a "white wash" of light weight spackle. I actually sprayed it on. Then sanded to 400 grit. It filled the grain well. I don't have a clue how much weight it added. At the time I wasn't concerned about weight.
Ken
Old 01-16-2017, 02:40 AM
  #638
Jason Arnold
Yesterday I started cutting some film templates for the stab top on the CNC. I'm extremely happy with the results and they work very well.
ID:	2196940   Click image for larger version
ID:	2196941   Click image for larger version
ID:	2196942   Click image for larger version
ID:	2196943   Click image for larger version
ID:	2196944   Click image for larger version
Old 01-16-2017, 03:29 AM
  #639
drac1
drac1's Avatar
You need a vinyl cutter and just cut the film out.
Old 01-16-2017, 09:19 AM
  #640
Stuart Chale
Agree, if these are templates to cut out your covering please see
http://www.rcuniverse.com/forum/rc-p...-covering.html
Stuart
Old 01-16-2017, 05:39 PM
  #641
Jason Arnold
Hey Scott,
I have a CNC router so spending $500+ on a Vinyl cutter makes no sense to me. I could put a lesser amount into a drag knife that fits the CNC router to perform the exact same task. This is what Peter Haase is doing.
These templates, once cut, can be used to cut the film parts very quickly and reliably. The weight of the template holds the film nice and flat too. At the end of the day, the templates will do the job asked of them very well. No stuffing about with setting depth of cuts or tacking the film down etc either. They could also be easily used to cut film parts for others if needed too. ;-)
Cheers,
Jason.
Old 01-16-2017, 06:09 PM
  #642
drac1
drac1's Avatar
Hey Scott,
Cheers,
Jason.
My hand cut cardboard ones worked OK, just needed to be careful that the knife didn't cut into the template.
Old 01-17-2017, 02:26 AM
  #643
Jason Arnold
I was going to do a similar thing but then thought stuff it, I'll just cut the templates direct on the CNC. Eliminate the possibility for error. The material use was 3mm PVC sheet from Bunnings. They could also be made out of Lite Ply or MDF too but I hadn't machined plastic on the CNC so decided to have a whirl at it.
Cheers,
Jason.
Old 01-17-2017, 08:31 AM
  #644
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
I have used the cardboard template approach myself and it worked great.
I do need to make sure the templates for top film pieces are sized about 2-3mm larger on all sides.
Old 01-17-2017, 12:17 PM
  #645
Jason Arnold
Yep, I allowed 3mm extra on all joins and 25mm overhang where there are no curves on the edges and 150mm overhang on the tips where some yanking material is needed. These templates are 3mm PVC so the knife doesn't worry them at all. I was going to go down the cardboard path as this was suggested by others. Doing it on the machine is so much easier and the Curves are perfect. Curves are hard to do freehand as you would know.
FWIW I did consider the vinyl cutter option as this is what Richard Hirst is using.
Cheers,
Jason.
Old 01-22-2017, 11:51 AM
  #646
Jason Arnold
Well, the first stab is completed. I didn't quite get the alignment perfect but I'm sure the next stab will be better. The weight came in at 93 grams which is within the target range. This stab is actually the heavier of the two as I was more liberal with the polyurethane glue during skinning than I should have been. We live and learn... lol
Cheers,
Jason.
ID:	2197688   Click image for larger version
ID:	2197689   Click image for larger version
ID:	2197690   Click image for larger version
ID:	2197691   Click image for larger version
Old 01-29-2017, 01:33 AM
  #647
Jason Arnold
Both stabs are now complete. The second stab came out at 90 grams. Adding a servo, linkage and horn should have the RTF weight at less than 130 grams.
Now to start on the wing film templates.
ID:	2198702   Click image for larger version
ID:	2198703   Click image for larger version
ID:	2198704   Click image for larger version
Old 02-13-2017, 12:34 PM
  #648
Jason Arnold
Hi Guys,
Not much progress on the builders kit due to the heatwave downunder. Bring on winter!
Anyway, I did manage to figure out how to cut all film templates in one go. In Fusion 360 I copied all the colour components to a new drawing and then positioned them to allow enough gap between each part. The run time on the router will be 2 hours and 6 minutes!
Another thing slowing me down is surfacing the whole bed of the CNC. So far I've only been making small parts and just surfaced a 2' x 1.5' piece of MDF. My surfacing bit does a top job but the dust is way to much so the extractor needs to be fixed before I proceed with surfacing the whole table.
I've started fitting the Ralph Schweizer CRS to the fuse as well. The phenolic nose ring fell victim to a Dremel party held at my place last Sunday. The nose ring must be removed so the Ply firewall can be mounted as far forward as possible. Not a fun job but it's done!
I used both ply spacer rings (4mm AC Ply) on the CRS to get the drive poking out the nose of the model. The 85mm spinner is being used here which matches the Allure nose nice. The backplate however is recessed by about 6mm hence the drive needing to poke out the front.
The firewall was aligned on the outside of the nose ring first to make sure it's centred and then drill the three M4 mounting holes.Once the firewall is aligned and glued in the fuse will be trimmed to match the firewall. This allows the whole CRS to be removed from the front of the model for maintenance.
The last picture shows the alignment/drilling jig for the CRS. An 8mm threaded steel rod or carbon rod can be inserted into this to align the firewall in the fuse. Down thrust is easy with the Wixey placed on the rod. Side thrust can be set a couple of ways. Either place the rod in the middle of the fuse or measure with the wing tube as a reference. A combination of both may be useful too to confirm alignment.
Cheers,
Jason.
ID:	2200922   Click image for larger version
ID:	2200927   Click image for larger version
ID:	2200928   Click image for larger version
ID:	2200929   Click image for larger version
ID:	2200930   Click image for larger version
Old 02-26-2017, 12:06 PM
  #649
Jason Arnold
I finished fitting the new V2 stabs and put five flights on them this afternoon in strong straight in your face wind conditions.
All went very well. Not one click of elevator trim needed either which was somewhat surprising.
Not sure if it's the stabs, new MKS servos, Precision Aero Product control horns or all three but the elevator feels much more precise and soft. It's most noticeable at the radius on the bottom of a down line.
The spins seem more consistent with regards to stopping the spin where it's supposed to stop.
Snaps seem faster too. Consecutive KE snaps held their line very nicely in the strong cross wind.
Overall 34 grams was saved with the new stabs and shortening the adjuster pin by 4".
The trimming continues but overall the V2 stabs are an improvement...
Thank you to Bryan Hebert of CK Aero and Aun at Xtreme Composite
Cheers,
Jason.
Name:	Ready to Cut Servo Holes.jpg
ID:	2203235   Click image for larger version
Name:	All Fitted.jpg
ID:	2203236   Click image for larger version
Name:	All Installed.jpg
ID:	2203237   Click image for larger version
Name:	Up Elevator.jpg
ID:	2203238   Click image for larger version
Name:	Up Elevator 2.jpg
ID:	2203239   Click image for larger version
Name:	Down Elevator.jpg
ID:	2203240   Click image for larger version
Name:	Left Stab Weight.jpg
ID:	2203241   Click image for larger version
Name:	Right Stab Weight.jpg
Name:	Old Stabs Total Weight.jpg
ID:	2203243   Click image for larger version
Name:	New Stabs Total Weight.jpg
ID:	2203244   Click image for larger version
ID:	2203245   Click image for larger version
Name:	Ready for First Flight.jpg
ID:	2203246   Click image for larger version
ID:	2203247   Click image for larger version
Name:	At the Field 2.jpg
ID:	2203248   Click image for larger version
Name:	At the Field.jpg
Last edited by Jason Arnold; 02-27-2017 at 01:58 PM. Reason: Images not working right. :-(
Old 02-27-2017, 01:36 PM
  #650
jonathan7x70
Hey guys,
I bought my first pattern plane. The CK Allure. Are there any more cost efficient electric motors that will work besides the $200.00 + F3A motors?
Thanks!
ID:	2203233   Click image for larger version
