Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Motor/prop/battery selection
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 11-06-2021, 11:17 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Default Motor/prop/battery selection - Pattern Glider!
Hey guys! So, this is for a 'glider' but this is the community I wanted to ask, so I'm posting here. I hope you don't mind!
I'm assembling a composite aerobatic glider (Fox): 3M span, 1.5M length, 3.5kg max weight (all-up.) I'd say 15" prop looks right, 14-16" range. I'll be flying sequences with it, and if I'm going to power it I might as well put something that can pull it like a pattern plane.
Any suggestions for motor and voltage? Or maybe just power rating, and/or prop diameter and rpm?
I'm in Hawaii and there isn't much room to fly 2M pattern here, but I miss sequences so I figured I'd try this!
Thanks!
Joe Garfield
Former D1 and Former D4
Old 11-07-2021, 08:48 PM
ltc
Have you tried running some numbers through eCalc?
https://www.ecalc.ch/
There is the free version that only with a for Hacker motors but you can easily translate a Hacker to a similar motor
https://www.hacker-motor-shop.com/Ha...catalog&p=7334
Another totally different option would be mounting a Xicoy x45 micro turbine on the glider … should have no difficulty flying sequences with that !
The Jeemo glider is specifically designed for this and there are a few videos available showing it online
http://www.glider-it.com/index.php/e...er-model-jeemo
Jetdesign (11-07-2021)
Old 11-07-2021, 08:50 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Thanks ltc I did start playing with a calc but was just hoping to find a good reference point to start from. I found the 62" Acuity and think I'll model my power system after that: 5s, ~500kv, 15x10 prop.
Old 11-07-2021, 09:32 PM
ltc
Another potential option would be to purchase a Varioprop from Christian at Ramomer.de
For this application you could perhaps consider a standard 2 blade Varioprop or even his folding 2 blade Varioprop
varioPROP
Easy to adjust the pitch to “tune” the motor power
(I ordered a 3 blade version for a winter 2m build and I’m waiting for DHL to deliver it)
