JETI 90?
I returned my Spin 99, i got a Jeti 90 instead, with the programming card. My question once you move the jumpers where you want them to be, and plug in the ESC, and 4.8 volt batterry, should you hear a beep or not. I did what the instruction said, but was not sure if I was suppose to hear a beep. when I hooked it up to my motor and receiver I heard five beeps, and the brake was on just like I wanted to be. Just wondering if my settings got saved.
TIA
TIA
okay for any of you folks that may be buying a Jeti 90, here is the procedure I received yesterday from Hobby Lobby. Plug in speed controller to motor, then ESC into programming. Attach 4.8 vot battery to prgramming card. Attach your battery pack to ESC, adn you shoud here one beep. If you hear the beep it is prgrammed.
