RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Beryll Flight Reports? (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/4257919-beryll-flight-reports.html)
mwick 05-09-2006 10:35 AM
I know there are not many of the new Matt designed Beryll out there yet, but was wondering if there are any flight reports?
Surefire 05-09-2006 11:06 AM
RE: Beryll Flight Reports?
I was fortunate enough to get a Beryll and I am putting it together now. I hope to have a first flight within a month or so. I will post a flight report then. The "kit" is beautiful, usual Oxai high quality.
Jon Carter
mwick 05-09-2006 12:06 PM
Jon:
What is your anticipated power setup? We would love to see some pictures.
Mike
Surefire 05-10-2006 10:12 AM
Mike - I will be running the Hacker C50 14XL Competition motor with the 6.7:1 gearbox and the 90A speed control. My plan is to use the TP5300 10S4P batteries. I am currently flying an electric Angels Shadow with the same basic setup (it has the regular Hacker C50 14XL) and it works great. All of the power that you could ever want and, so far, great reliability. I basically went to school on Tony Frackowiak and Jerry Budd out here and copied their equipment setup (Thanks guys!) I am a firm believer in "imitation being the sincerest form of flattery"
I will try and post some pictures later this week.
Jon Carter
mwick 06-05-2006 10:27 AM
Jon:
Any updates on your Beryll?
Surefire 06-05-2006 11:02 AM
O.K. ! I will really try and get some pictures up later this week. I am hoping to do the first flight this coming Sunday. Work and a nasty cold have slowed me down somewhat.
Jon Carter
Surefire 06-12-2006 11:14 AM
I did the first flight on the Beryll on Sunday. It was great! :D I still don't have any pictures but Scott Covey took some video and it's on the NSRCA D7 website (http://www.nsrca.org/d7/) I set up the control throws the same as my electric Angels Shadow and they are all about right. I set the wing at 0 and the stab at 1/2. The plane took about 6 "beeps" of up elevator trim and about two "beeps" of right aileron. (I have my trims pretty de-sensitized so that's not very much control surface movement) I put 4 fairly easy flights on it gradually building up to snaps and spins on the last flight and everything went very well. It has a touch of pull to the belly on knife but just a touch. The up and down lines were very straight. (Except for my wobbles!) It's a beautiful plane and it seems to fly as good as it looks. I think the Matt's have another winner here!
Jon Carter
mwick 06-12-2006 12:17 PM
Jon;
I've watched the video twice, I like the way the plane presents. Now the questions begin
Do you have an all up weight yet?
Two elevator servos in the stab or single with DEPS or other similar system?
Where did the CG end up?
Did you really mean that the stab was 1/2 positive to the wing or vice versa?
Mike
Surefire 06-12-2006 03:24 PM
Mike - The plane really does present well! It's got a really nice constant speed "look" to it.
The real (no kidding) all up weight is 10lbs 15oz. I'm 1 oz under the limit. I didn't really go out of my way to be truly fanatical about weight reduction. At the same time I tried not to add any extra weight either. My Angels Shadow-e is 10 lbs 8oz. That said, the Beryll flies very "light" to my feeling.
I am running two Futaba 9650 mini digitals in the stab. I am also running the 9650's for the ailerons.
Per an e-mail from Wolfgang Matt I set the C/G at 175mm from the wing leading edge.
My starting point for incidence was putting the stab incidence 1/2 degree negative to the wing. (I am not usually super careful with this because I always find myself adjusting wing and sometimes stab incidence based on flight performance)
I will post more as I trim it out.
Jon Carter
patrnflyr 06-12-2006 05:44 PM
What a beautiful website! Thanks for sharing that video with us. Hope all the test flights go well. Someday, I'll be going electric! I just have too much invested in my brand new Angel's Shadow/YS at the present time.
John S. Johnson
Lubbock, TX
Surefire 06-13-2006 10:38 AM
The website is really great. Scott Covey is our webmaster and he has really "pumped" up the site. He uses a wireless hookup and actually puts preliminary contest scores up as the contest is going!
The Angels Shadow is a great plane also. That's what I've been competing with for the past 4 years. I currently have about 85 flights on my electric Angels Shadow and I really like it. It will be a tough choice as I get more familiar with the Beryll of which plane to fly!:D
Jon Carter
flyf3a 10-09-2006 01:36 AM
Hi
Have about 20 flights on my Beryll. Do you also find that there was to much right thrust at the start? Had to reduce by a bit.
flyf3a 10-09-2006 02:02 AM
Hi
The Beryll is an absolute beautiful plane with exceptional paint quality. After flying an Impact it is a great improvement, but obviously very costly. Can buy two Impacts for the price of one Beryll, and I got mine directly from OXAI. The nice thing is that every set up is done by OXAI and can be trusted. Took two days from work and plane was ready to fly. The only aspect that I had to change to date is to reduce the right thrust. At half throttle it is ok but anything more and it pulls quite a lot to the right. I am almost there. Tucks a little to the belly on knife edge, about 5% up elevator mixing on JR 10X. Rolls are axial and snaps are great. Flying Hacker Comp 14 XL with APC 21X13 E wide blade and TP 5300 batteries. And this is the greatest, all up weight 4,802 KG. I used some of this available weight by building a removable battery tray untill all the CG set up was complete and prop selection finalized. The batteries do not go on the intended place on the front tray and had to be moved back to get correct cg.
Will post some stats and pictures.
mwick 10-09-2006 11:43 AM
flyf3a:
We are getting ready to finish off our Beryll. Pics and stats of your final setup would be fantastic.
Mike Wickizer
Surefire 10-09-2006 11:44 AM
I have not noticed a need to change the right thrust. I also have a mix in to fix the tuck to the belly on knife edge (~ 5% also) I have ~ 70 flights now and I am really liking the way the Beryll flys. I have moved the CG back a bit from the starting point (175mm back from the leading edge) I am at about 185mm now.
The Beryll flys so great that I might have to try and get another one!
Jon Carter
flyf3a 10-11-2006 06:01 AM
1 Attachment(s)
Hi
Kit weight from Oxai was 2320 grams and weight at maiden flight was 4706 grams. Will measure throws and setup tonight and post. Attached some photos.
flyf3a 10-11-2006 06:38 AM
Hi there
Some general stats on the Oxai kit in grams out of the box for those that want to compare apples with apples.
Stabs 94 grams left and right
Wings 374 grams left and right
Landing gears 73 grams left and 68 grams right. If you use ZN Line gears they weigh 37 grams each.
Spats 16 grams left and right
Canopy 183 grams
Fuselage including rudder and all formers already installed 969 grams.
Wing joiner tube 57 grams and stab joiner tube 8 grams
The wings and stabs are pre manufacturred for Futaba servos and rather than butchering the beautiful finish I opted for these rather than my usual JR servos. Using 8411 on rudder and JR PCM 10 X. Out of box to fly in two days, only install radio, fix gears, spats and engine.
15 mm throw on ailerons (10 % exp) and 10 mm on elevator (15% exp). Rudder max throw with (50% exp). 8 point throttle curve as with Hacker no use for more than half throttle to fly most of the F3A schedule. Only mix is ruder to elevator for knife edge flight.
All linkages are MK, MK tail wheel and power box digi swith (only 15 grams). Control horns from ZN Line as my kit did not have these although I paid for it. No spinner was included in kit although again paid for and opted for Carbon spinner 82 mm.
EVO 20 (1200mah) receiver battery, will give more than 5 flights easy.
mwick 10-11-2006 03:39 PM
F3A:
Thanks for the information. Our airframe has very similar weights. You have done a nice job finishing it off.
thanks
tuan lam 10-18-2006 05:10 PM
hi,mike
tuan here if you remember ! I got the beryll on monday but the finished of mine is diffirent from your maybe we can get together and see (if I known how!!) and try to get some idear from you also. thankyou
tuan
Heer 10-20-2006 01:50 PM
1 Attachment(s)
Hi
after 30 flights with the Beryll i will say, this plane isn't only a beauty - it is a perfect flying pattern model.
No words about quality - forget all other F3A-planes on the market !
Regards Fritz/Switzerland
underwood1 10-20-2006 02:36 PM
hi heer,
what power set up are you using in your beryll,lovely looking plane!!!
rgds
underwood
Heer 10-21-2006 01:35 PM
1 Attachment(s)
Hi underwood
Motor: Hacker C50-15 XL Acro Comp with Hacker Master 90-0-Acro-Comp.
Prop: APC 22 x 12 E
Lipo: TP-5300/10S4P
Rx-Lipo: TP-480 2S with Digi-Switch Powerbox.Systems
BRG
Fritz
darkvader 10-21-2006 01:57 PM
Hi Heer,
What is the total Weight in Fly?
Heer 10-22-2006 02:24 PM
darkvader
4720 gr.
BRG Fritz
underwood1 10-26-2006 04:58 AM
hi heer ,
what flight time you getting on those t/p packs???,two schedules of po7.
regards
underwood
