Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Dumb Aerohawk owner needs help with canopy >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 05-06-2004 | 03:46 AM
coltech's Avatar
Default Dumb Aerohawk owner needs help with canopy
Can someone tell me how the canopy fits on an Aerohawk. Is the rod supposed to fit tightly into the grove? The only way I can fit it at the moment is to jam the bottom of the canopy on the battery to keep it in place.
The instruction manual is the worst I've ever seen!
Old 05-06-2004 | 10:51 AM
Default RE: Dumb Aerohawk owner needs help with canopy
the rod that should be on the front of the aerohawk is what holds it on. slide the bar through the grommets on the cannapy.
Old 05-06-2004 | 02:17 PM
coltech's Avatar
The rod goes thru the grommets and sits in a groove. Should the rod fit tightly in the groove ( like Dragonfly/Hummingbird) ? Mine just sits on it.
Old 05-06-2004 | 09:20 PM
should be real tight....you could glue it in there if this is a problem.
Old 05-08-2004 | 11:11 AM
My Aerohawk came with the canopy fitted and the bar was glued into the groove....
Old 05-10-2004 | 03:59 PM
lineman55's Avatar
Once you poke the glued rod through the rubber grommets on the canopy,use a small piece of rubber fuel tubing to hold it if needed over the ends of the carbon rod.
Cheers
