will a hitec laser work with cp
WI
well i have been looking into getting the new HB pro 3d with the brushless and i got a 6 channel hitec laser radio, will this work and if not is their a way i can get it to work, thanx
MA
Sorry I missed that your laser would work on another heli without CCPM, for example Shogun/T-rex. But in the case of the HB 3d PRO, it requires a computerized TX for the eCCPM to work. Hope that helps.
ZipPhReaK
ZipPhReaK
Banned
My Feedback: (14)
For CCPM you need a computer radio like the Futaba 9C a laser 6 will not work with ccpm because it is not a computer radio,there is a way to do ccpm mixing using mechanics but I do not know how this is done,it is used with the Ikarus Eco 8 but I do not know anything about it,it says that you can fly the Eco 8 with the laser 4 buy using that ccpm mix but again it is unknown how it is done.
WI
what about something bigger, i was looking at a corona but i dont know about the wood chissis, but with the kit for 240$ it says it includes and aluminum chassis so does that get rid of all that wood, and are these more stable then hummingbirds?
NY
Sorry my bad, I thought you mean HoneyBee 2 instead of HummingBird 2.
The smallest corona I know of is still an outdoor heli. HB is indoors so the question is are u getting one for indoor or outdoors?
Don't forget about accessories like battery. You going to need a bigger one for the corona and Lipos are pretty expensive.
WI
well i got 3 7 cell battery packs, (for cars) i will probobly have about 60-90$ to spend after the 240$ for the corona motor package, and thing you'd suggest? would a gym be a big enough to do some slow flying? like you know, hovering and learning? and is the corona pretty easy to fly? i can hover the hummingbird a little, and from what i hear if u can hover one of those you can hover anything, thanks
