Highest voltage for blade cp electronics?
I'm going to build a few packs for my blade cp and I need to know how much voltage the stock electronics can handle. I plan on using some 2/3a matched cells in either 1100 or 1150mah ratings. I can use 8-10 cells but I don't want to fry any electronics.
Are you building lipos or NiMh packs? I wouldn't go far above 12vdc.
4-cell lipos at 14vdc would really be pushing it and would fry the 4-in-1 eventually.
lipos don't come in "A" ratings. hence the 2/3a I am using. They are super cheap at $0.98 a cell and I don't have to buy a special charger.
Thanks for the info guys!
Gotcha. I built 9-cell NiMh packs for my blade. They run really good, better than the 8-cell stock batteries. Upgraded to lipos now and it's almost impossible to go back to NiMh after you fly with those.
Actually, since I was using my first heli, DF#4, as spare parts (crappy machine) I had 3 stock 7-cells from that one.
I split 1 battery up and added 2 cells each to the other 2 packs making 2 9-cells packs. Confused yet?
The DF#4 has those green 7-cell battery packs. Configuration below.
O O O O
O O O
After adding 2 cells to each one they look like this:
O O O O
O O O
O O
The weight of 1 extra cell is no problem at all.
O O O O
O O O
O O O O
O O O
O O
CA
I flew with 9 cells on my Blade CP with the aero kit and then switch over to 10C 3S 900maH lipo. What a day and night different; with the lipo pack, you don't have to deal with the constant tail trimming problem and you can feel she's lighter and more responsive.
